  • Member For: 21y 8m 26d
Gents
My boot leaks like no tomorrow. I was wondering if anyone else has this problem and if so what did you do about it. My dealer said that it has to go to a panel shop to fix it. A couple of other 'T' owners that I know have the same problem.
Any comments?
https://www.fordxr6turbo.com/forum/topic/10230-leaking-boot/
  • Firm Member
  • Member For: 22y 6m 2d
Gents
Any comments?
Its pretty drastic that it needs to go to a body shop. l wonder if there is some misalingned panel or very poor panel fit that requires a bit of MIG action to rectify?
Can your dealer tell you more on what is needed?
https://www.fordxr6turbo.com/forum/topic/10230-leaking-boot/#findComment-112260
  • Member For: 22y 16d
Depends on where it is leaking. I seem to remember something about the screws being to long or to wide on the numberplate causing water to enter into the boot. This is usually a dealer problem as they put on the numberplates for you when they register the car. AU series had the same fault with leaking boot from the same cause. I think the fix was to bog up the holes and make new ones with the correct sized screws, hence the need for a pannel shop.
https://www.fordxr6turbo.com/forum/topic/10230-leaking-boot/#findComment-112296
