BoostedG6E
    6
BoostedG6E last won the day on April 6 2024
BoostedG6E had the most liked content!
23 Excellent
About BoostedG6E
  • Birthday January 6
    Melbourne
  1. Did you upgrade the fuel pump wiring when installing the 460? Potentially a wiring issue. during the 10-15 minutes can you hear the pump priming when ignition on?
  2. HPC Coating also[emoji106]
  3. My tuner just got back to me and turns out I will only need the 5bar tmap and can repurpose the boost sensor input. https://www.independentmotorsports.com.au/5-bar-t-map-sensor-omnipower
  4. Woops I sent the wrong one, https://www.efisolutions.com.au/bosch-pressure-temp-map-sensor-tmap-4.0-bar-sensor. This was the Tmap I was going to get. I am running a haltech PNP in the car now so not sure if I will need to upgrade both or if doing one is sufficient.
  5. Hi All, Just about finishing up on my new build and I currently only have a 3 bar map sensor, looking to upgrade to a 4 bar (https://www.efisolutions.com.au/bosch-pressure-sensor-4.0-bar-intercooler-pipe-loc), however am wondering if I will also need to upgrade my boost sensor pre throttle body also?
  6. Yeah hopefully man, Just putting some k’s on the engine and got a new set of clutches in the zf also so need to get it all run in before I hit the dyno. I only got a Set of 1650 injectors on it so around the 650rwkw mark for now will be the aim.
  7. Con from pro race engines.
  8. Hey mate, all up and running and the sound is definitely gone now.
  9. Engines going in tomorrow mate, won’t be a few weeks till it’s going as need to get some piping done.
  10. Hi all, just fitting a pulsar g42 with a high mount manifold and am trying to sort out the oil return situation, just looking to see what fittings people are using for high mount setups, Was looking at the attached photo however I read a post on Facebook of guy using a similar fitting and not working. Any help will be greatly appreciated.
  11. Okay perfect thanks for the reply!! Turns out the clearances where to lose so have had to get a new set of bushes and machine it all up to suit.
  12. Has anyone had experience with spool rods, Have taken the Gudgeon Pin sleeve out and have this rough finish. Is this normal or should this been machined?
  13. Nah nothing yet, Few delays. Hopefully engines finished soon.
  14. Funny you say that🤣, Just sent them off today to get coated.
  15. Yeah mate [emoji106]
