Benfu86
Everything posted by Benfu86
  1. the a/f ratio won't be right, that's why you need a tune
  2. venom cat no tune = more money spend on engine when is boom..
  3. Before you even go for mods, I would suggest get a new coil pack, plugs, fuel filter, fuel pump. That will give you a peace of mind and should solve this problem. If problem still there, you should take it to a proper tuner who knows this kind of car well.
  4. You know how you have the extension from driver to passenger side? On the passenger side one was loose. All good now
  5. Tune and loose wiring
  6. All fixed today
  7. Thanks all. Hope to fix this soon
  8. Assuming that wiring and connection are all good. What could it be?
  9. Any idea Mick?
  10. happen just recently?
  11. Just read dtc the second time today. It has new code now p0236, turbo/super charger boost a ckt range/performance. What could it be with 2 code on at the same time. Can a modified actuator and ported wastegate cause this or just need to be re-tune?
  12. Plug in properly. Yes, there is an extended wiring loom from driver to passenger side. Running plazamaman 800hp inter cooler with CAI and BOV.
  13. Just pick up car from tuner.
  14. I have this code on my car p0238 saying that turbo/super charger boost A (tc/sbc-a) ckt high. It's a BA T. Anybody has any info about this? Cheers
  15. I just need some advice on turbo mods, the most common one, changing of actuator and ported wastegate. Is it alright to skip that or it will create boost creep. Can tuner disable the car ecu that control boost to avoid overboost? Here are the mods, walbro fuel pump, plazamaman inter cooler with under battery CAI done. Valve spring, injector, 4" dump>3.5 cat with standard back and tune pending. Still deciding whether to mods the turbo or not in one hit.
  16. Thanks for the info, will look into it
  17. anybody knows 4 piston callipers that fits stock 17" wheels?
  18. Is that 4 piston?
  19. Heard that Brembos required 18" wheels. AP racing, PBR, etc? Any recommendation?
  20. Just got home, it's like a ghost street... lol
  21. check fuel pump
  22. when was the last time you had the boost solenoid change? Clean doen't mean good. I have the same problem before.
  23. Car is fixed. Change Boost Solenoid, and fuel filter.
  24. No noise mate
