Eugene Member 670 Member For: 19y 7m 13d Gender: Male Location: Newcastle NSW Posted 22/09/04 05:47 AM Share Posted 22/09/04 05:47 AM (edited) Hello to all,I got into the Ute last night and fitted a 3" (75mm) ID CAI.It was a tight squeeze, but by removing the LH headlight bolts, including the on up inside the inner guard (deadset mongrel to get onto) the headlight came foward far enough to allow the flex tube to fit.I got the tube from Clarke Rubber , it was about $40 per meter, I got a meter to be sure I had enough.I got the flange fitting from Home Hardware, it is a gallvanized guttering fitting that tapers from 70mm to 75mm with 6 mm flange on the big end, it was about 3" long so I cut it back to 1 1/4".I ran the tube up from the Lower grill, behind the fog light, up beside the washer bottle, and out through the now larger gap between the haedlight and front radiator support panel.stainless hose clamp to secure and bobs your aunty, Job done.Also fitted the K&N Air filter I got off ebay the other night for $67. + $10 postage, it also came with a new recharge kit. Edited 22/09/04 05:48 AM by Eugene Link to comment Share on other sites More sharing options...
Eugene Member 670 Member For: 19y 7m 13d Gender: Male Location: Newcastle NSW Posted 22/09/04 05:50 AM Author Share Posted 22/09/04 05:50 AM (edited) behind the light before box is refitted Edited 22/09/04 05:54 AM by Eugene Link to comment Share on other sites More sharing options...
Eugene Member 670 Member For: 19y 7m 13d Gender: Male Location: Newcastle NSW Posted 22/09/04 05:51 AM Author Share Posted 22/09/04 05:51 AM (edited) Air box and headlight refitted. Edited 22/09/04 05:53 AM by Eugene Link to comment Share on other sites More sharing options...
Eugene Member 670 Member For: 19y 7m 13d Gender: Male Location: Newcastle NSW Posted 22/09/04 05:54 AM Author Share Posted 22/09/04 05:54 AM Inside the box Link to comment Share on other sites More sharing options...
Eugene Member 670 Member For: 19y 7m 13d Gender: Male Location: Newcastle NSW Posted 22/09/04 06:02 AM Author Share Posted 22/09/04 06:02 AM (edited) from the front, I am now making a plate to hold the hose in position, further back than it is in the photo, it will mount to the bolt just above the tube, it should be done tonight.I did a run to Syney on the weekend before the mod and got 11.2 lt/100k 365km of highway and city driving. dash display said 12.4lt averageNew avaerge for today, (I have only donE 300km), same fuel same load, dash display now says 11.1 lt/per 100.I will let you know tommorow when I fill up again how it went for economy.I definitaly pulls harder, where it would start to die around 5400rpm and be flat by 5600-5700rpm, it now pulls clean to 5700-5800rpm, maybe it my imagination, but it feels better up top, no noticable difference down low, but my car only has 3800km on it so we will wait and see.Centre muffler comes out either tommorow, or early next week. Edited 22/09/04 06:04 AM by Eugene Link to comment Share on other sites More sharing options...
Guest Guests Posted 22/09/04 06:19 AM Share Posted 22/09/04 06:19 AM Nice to see a keen worker,good on ya mate!!!Ive done the same thing,but stopped under the headlight.I figured if its good enough for the V8s,then its a bonus for the TI cut my pipe at 45 degrees so the front of it is up to the grill,and the top is near the light,so you cant see anything vik Link to comment Share on other sites More sharing options...
Blown BA In Your Face Member 6,195 Member For: 21y 1m 20d Gender: Male Location: Peninsula Posted 22/09/04 06:28 AM Share Posted 22/09/04 06:28 AM Nice work Eug Link to comment Share on other sites More sharing options...
FG50T Member 568 Member For: 20y 2m 15d Gender: Male Location: Melbourne Posted 22/09/04 07:28 AM Share Posted 22/09/04 07:28 AM Nice work ...oh yeah and give your intercooler a clean. Link to comment Share on other sites More sharing options...
ktford FORD FORD FORD Donating Members 9,390 Member For: 21y 1m 11d Gender: Male Location: Victoria Point In Brissy's eastern side Posted 22/09/04 07:36 AM Share Posted 22/09/04 07:36 AM I am now making a plate to hold the hose in position I used a little AC duct holder, works a treat.Scotty Link to comment Share on other sites More sharing options...
YOOT Member 1,201 Member For: 20y 10m 9d Location: Birkdale Posted 22/09/04 09:51 AM Share Posted 22/09/04 09:51 AM That might explain why my Fuel economy dropped from 14.3 to 11.8 in the last month after I fitted the exact same pipe and K&N.I noticed much better off boost torque and stronger top end too. Especially in the cold. Also you could feel the air rushing in the snorkle like a vacuum cleaner before the mod, now you can barely feel it because the potential difference across the two intakes more or less is halved. So its gotta be a good thing!Can't wait to get my centre muff removed now! Link to comment Share on other sites More sharing options...
