Turbo6man Legacy Donating Member 4,084 Member For: 23y 11m 8d Gender: Male Location: South Coast NSW Posted 07/07/08 07:02 AM Posted 07/07/08 07:02 AM For a moderator you should know not to bother posting something stupid like that. If you don't understand the problem or have anything useful to say, pipe down.As a moderator I am able to discern real problems from imaginary ones. Something you as a non-moderator can not.Lighten up mate, only stirring ... Hey Tabbitha, any fish biting up your way? They're really ON down here!
tab Sucker Moderating Team 32,303 Member For: 22y 4m 25d Gender: Male Location: Brisbane Posted 07/07/08 07:07 AM Posted 07/07/08 07:07 AM FG XR6-T, Ego, 6 Speed Manual, Prem Audio.Nuff said
dave- Member 157 Member For: 21y 9m 9d Location: Melbourne Posted 22/07/08 10:56 AM Author Posted 22/07/08 10:56 AM So still no tinkering by fleet drivers?
xr6_2001 Member 81 Member For: 19y 4m 27d Gender: Male Location: Radelaide Posted 01/09/08 02:40 AM Posted 01/09/08 02:40 AM Found it!, anyone else interested it's in the fuse box pull off panel near the drivers door,hard to describe but, on the right hand side once your take the cover off, down the bottom there is a main plug with many wires going to it, there is white wire that has a yellow clip on it, just unplug the clip and the always on lights is disabled.
dave- Member 157 Member For: 21y 9m 9d Location: Melbourne Posted 03/09/08 04:38 AM Author Posted 03/09/08 04:38 AM (edited) Found it!, anyone else interested it's in the fuse box pull off panel near the drivers door,hard to describe but, on the right hand side once your take the cover off, down the bottom there is a main plug with many wires going to it, there is white wire that has a yellow clip on it, just unplug the clip and the always on lights is disabled.Thanks for the PM too, I'd forgot to subscribe to my own thread Here is the wire xr6_2001 is talking about:Mine was crimped on so instead of ripping it off, I tried tracing the wire but didn't get far so I went fishing again under the dash... and found what looked almost identical to the module used on the old BA's I had:Peeling away some of the foam taping at the end, there is a clip on the side which opens it up to show a 5A blade fuse. With that removed the stupid fleet system is defeated:Reason I couldn't find it the first time is the dealer did a much better job fitting it this time and had hidden it well up under the dash. On my BA's it was pretty much just hanging above the pedals near the steering column. Thanks again xr6_2001! Edited 03/09/08 04:40 AM by dave-
