SHMIKO_S14A New Member 22 Member For: 8y 6d Posted 12/08/17 12:21 PM Share Posted 12/08/17 12:21 PM Hey guys, gonna describe this issue as best as I can. I've got a Barra 240t BTR auto in BA XT. Car is sometimes giving itself throttle without any throttle input. I know these cars have drive by wire throttle, could it be an issue with this? For example if I'm cruising along in drive the car starts speeding up by itself, if I put it into neutral the revs start climbing up and then generally fall back to normal idle after a few seconds. I know the auto trans has some issues and I am waiting for some cash to give it a full rebuild, wondering whether something in the auto trans is doing this? Cheers in advance. Link to comment https://www.fordxr6turbo.com/forum/topic/93429-rpm-increasing-without-throttle-input/ Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 6m 13d Gender: Not Telling Posted 13/08/17 12:04 AM Share Posted 13/08/17 12:04 AM (edited) maybe a intake manifold gasket leak or some sort of vacuum leak. trans could always be slipping though causing the revs to spike, dunno what would cause that to happen in neutral though. Edited 13/08/17 12:05 AM by skidxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/93429-rpm-increasing-without-throttle-input/#findComment-1643582 Share on other sites More sharing options...
SHMIKO_S14A New Member 22 Member For: 8y 6d Posted 15/08/17 09:05 AM Author Share Posted 15/08/17 09:05 AM The car does it intermittently, only 1% of the time so I don't think it's a vacuum leak. Is there a possibility that the drive by wire system is faulty or that there is something Erin with the ecu? I'm 99% sure that it's an electronic issue not mechanical. Link to comment https://www.fordxr6turbo.com/forum/topic/93429-rpm-increasing-without-throttle-input/#findComment-1643651 Share on other sites More sharing options...
