dsheps83 Member 19 Member For: 15y 27d Posted 31/08/16 01:52 AM Share Posted 31/08/16 01:52 AM had a few issues with this poor car, BA Straight 6 My latest is when its cold runs fine has heaps of power, once it gets to operating temp it isn't as powerful, and surges can be felt above 60kph. when I had cam issues is swapped out the cams and the cradle caps with the vct actuators from a slightly later model, which where a slightly different design. the surge happens every 5 to 6 seconds when cruising at highway speed. Could the vct from a later model be the cause? stil had the same oil holes? Have Checked Fuel pump - New fuel pressure regulator - Swapped coils - Swapped spark plugs with diaelectric grease - 5000km old knock sensor - Swapped crank angle sensor - Swapped cam angle sensors - Swapped throttle body (tps) - Swapped fuel filter - New fuel pump relay - Swapped injectors - Swapped 02 sensor - New None of these changes made a difference and the swapped items work fine on my other running car Except the fuel related items I was confident that it wasn't any of these as it runs perfect until it gets to its operating temp, somewhere around the 70c to 75c mark it starts the surge. when it gets out of warm up mode does the timing with the cams change? Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,341 Member For: 16y 1m 3d Gender: Male Location: Melbourne Posted 31/08/16 01:56 AM Share Posted 31/08/16 01:56 AM has it had a tune to cope with the different cam sensors and cams? Link to comment Share on other sites More sharing options...
dsheps83 Member 19 Member For: 15y 27d Posted 31/08/16 02:02 AM Author Share Posted 31/08/16 02:02 AM the cams were stock cams from a later version of the BA, an 04 model as I have found out they have different vct actuators but everything looked like it lined up the same, as the car wasnt running properly before I did all this I cant say it was or wasnt this But to answer your question, No as I beleive the cams have the same profile Link to comment Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 11y 4m 15d Gender: Not Telling Posted 31/08/16 02:05 AM Share Posted 31/08/16 02:05 AM three types of VCT actuators if I recall right, one with a bolt hole and one without. then a third type that is shorter. did you change the oil after changing the vct actuators? have you flattened the accelerator while cranking engine for about 10 seconds? it resets something todo with the actuators finally can you scan for fault codes? Link to comment Share on other sites More sharing options...
dsheps83 Member 19 Member For: 15y 27d Posted 31/08/16 02:15 AM Author Share Posted 31/08/16 02:15 AM yeah there seems to be two different lengths that bolt on, I changed from one to the other changing the caps that they mount in. I did change the oil not sure if it was straight after or down the track a bit, is this going somewhere cos I do believe when I changed the oil the issue wasn't as bad, running penrite 10w-50 I think which made it slighty better. the reason why I changed the actuators was after cleaning them they still didn't move much and had another set from the motor I was getting the cams off, which moved a lot better Haven't done the hold the accelerator part might go do that now. And no codes display with the surging going on, I have an old ford flash that I can install the software on the laptop and take it for a spin, but if im not getting any codes I probably wouldn't see any issue even looking at the right sensors would I? Link to comment Share on other sites More sharing options...
dsheps83 Member 19 Member For: 15y 27d Posted 31/08/16 05:41 AM Author Share Posted 31/08/16 05:41 AM well just to update this I feel like a complete idiot at the moment, I thought well I have some vct sprockets here I'll just swap em out. well, when I took the rocker cover off and went to undo the cam sprocket bolt I noticed it wasn't tight, so I pulled the bolt out cleaned it put loctite and did it back up, went for a drive now its all good!!!!! I assume it wasn't tight enough to seal the oil passageway. as I left the car sitting for a long time I don't remember how I didn't have it done up, whether the cam kept turning the motor or I got distracted and never checked the tension I dunno. Thanks for the suggestions Link to comment Share on other sites More sharing options...
k31th less WHY; more WOT Site Developer 28,341 Member For: 16y 1m 3d Gender: Male Location: Melbourne Posted 31/08/16 05:43 AM Share Posted 31/08/16 05:43 AM I'd also look at the timing chain position to be 100% sure if you left it loose for a while. Good job on solving it, though! Link to comment Share on other sites More sharing options...
dsheps83 Member 19 Member For: 15y 27d Posted 31/08/16 06:02 AM Author Share Posted 31/08/16 06:02 AM yeah would have been a good idea, but I already put it back together and been driving it around, thought I would update, antoehr thing to check for anyone else that comes across this issue after changing thier cam Link to comment Share on other sites More sharing options...
