Brewy New Member 12 Member For: 1m 2d Posted 05/05/24 06:13 AM Share Posted 05/05/24 06:13 AM Hi, I have a 2003 BA XR6 Turbo Manual with 102,000km that I’ve owned since brand new and last time I drove it for about an hour with no problems and then it sat for about 6 hours and started it up and started to run rough after about 5 seconds and felt like it was on 4 cylinders with no power, so had to drive it home like this. When I got home, I connected my Autel Maxicom Pro Diagnostic Scan Tool, and it gave me 5 x Fault codes that was astonishing. PO352:63 / CMDTCs - Ignition Coil B primary circuit malfunction. PO354:63 / CMDTCs - Ignition Coil D Primary/Secondary Circuit. PO356:63 / CMDTCs - Ignition Coil F Primary/Secondary Circuit. P1708:00/ ODDTCs - Clutch switch input circuit malfunction. P1507:63 / CMDTCs – IAC(idle Control) valve duty cycle lower than expected. So, I put in all New Ignition coils, cleared the faults codes, and started it up and still ran rough after 5 seconds after startup, so scanned again and the faulty ignition coils wasn’t on diagnosis scan report, so thought that’s good, fixed that issue and only had the P1708:00/ ODDTCs - Clutch switch input circuit malfunction. So, when I went to start it for the second time, it wouldn’t start and the word ’’Code” was on the Audio Display Screen and when I try and start, the ’’Code” word goes Dim, but lights on dash still bright and works ok, and Audio doesn’t work. So thought maybe the Clutch switch input circuit malfunction was causing it to not start now, but I didn’t really think so, so just also to cover the 1 yr. old supercharge battery as well, I put it on the battery charger that night and took it to get tested at Autobarn the next day and all good and went bought Clutch switch from Ford and when we got home we checked the new and old clutch switch with multimeter for curiosity and the both had the same reading and thought maybe nothing wrong with old switch, but installed new clutch switch anyway and engine still runs rough after 5 seconds? So, don’t know if these replacements parts were really Faulty or ECU/PCM is playing up and throwing out weird codes, as its weird that had no problems and all of a sudden get 5 faulty parts codes? And now that it won’t start and Code word on Audio Display, Autel scan tool can’t connect to Vin Numbers in ECU, it comes up ‘’VIN Decoding Failed’’? And I’ve already pulled/cleaned ECU Plugs to no avail. So, it’s getting worst with more unexpected problems. So has anyone had this Issue before and what was the outcome. Thanks Link to comment Share on other sites More sharing options...
