  • Member For: 8y 10m 30d
Need a bit of info on an external wastegate setup? I’ve got a ba car with fg f6 engine, gen 2 gtx3582, 6boost manifold (standard position) and a manta 4” dump pipe. Where should I mount the external wastegate and why should I mount it there (this needs to be a plumb back system) and what wastegate would you recommend 500-550rwkw. Thanks
  • XR50T
  • Member For: 12y 1m 12d
Fit it to the rear housing, best spot for boost control and should plumb back fairly easily. Make sure the internal gate flap is welded shut.
