Weapon80 New Member 3 Member For: 8y 9m 1d Posted 04/10/16 10:11 AM Share Posted 04/10/16 10:11 AM Hi guys have an issue with my instruments in the morning when I start my car my rev counter will not pick up and the same for my fuel gauge sometimes..... winners has been running for a minute or two I can switch it off and then back on again and everything is normal but sometimes my rev counter is 1000 RPM out of whack help what's going on lol Link to comment https://www.fordxr6turbo.com/forum/topic/92515-2005-ba-xr6-turbo-gauge-problems/ Share on other sites More sharing options...
skidxr6t skids Donating Members 2,754 Member For: 12y 6m 7d Gender: Not Telling Posted 04/10/16 10:19 AM Share Posted 04/10/16 10:19 AM Stab in the dark - I have no idea whats causing this issue - but maybe there is a battery/voltage issue which can cause weird symptoms. Link to comment https://www.fordxr6turbo.com/forum/topic/92515-2005-ba-xr6-turbo-gauge-problems/#findComment-1615173 Share on other sites More sharing options...
ROB83R Member 1,632 Member For: 9y 1m 16d Gender: Not Telling Location: Radioactive wasteland Posted 04/10/16 10:41 AM Share Posted 04/10/16 10:41 AM It's a shagged battery. Mine used to do it. Is it hard to start sometimes? Sometimes stalls after it starts? Your cruise control won't turn on either? If it does any of these things I'm fairly certain it's the battery. The battery part number 67ef. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/92515-2005-ba-xr6-turbo-gauge-problems/#findComment-1615181 Share on other sites More sharing options...
Weapon80 New Member 3 Member For: 8y 9m 1d Posted 04/10/16 11:00 AM Author Share Posted 04/10/16 11:00 AM Thank you for your reply my car does not have any starting issues I have tested the battery and thus charging system is ok everything else works perfectly in the car although I have noticed sometimes when I come to a stop it will start idling low as if it is about to cut out and then that catches itself and runs normal I thought that might have been a vacuum leak but I have solely searched for that and has come up dry it seems to be odd that only the fuel gauge and the RPM counter plays up but if I turn it off and turn it back on again it all works normal Link to comment https://www.fordxr6turbo.com/forum/topic/92515-2005-ba-xr6-turbo-gauge-problems/#findComment-1615188 Share on other sites More sharing options...
