  • New Member
  • Member For: 9y 22d
Hi Team,
Due to my inability to find the answer (user error with keywords, probably), just what section of the sedan exhaust needs to be modified to fit a ute?
I get one has IRS and one is a solid rear end; but I'm just trying to confirm up until what point under the car does it no longer fit (I'm assume diff/drive shaft) then whole new rear section over rear end to tail?
Car: BA XR6T Ute
Thanks!
  • less WHY; more WOT
  • Site Developer
  • Member For: 17y 2m 20d
Your guess is correct. The sedan/ute exhaust is the same from the turbo back to approximately the tailshaft centre bearing region. Then it changes as it goes past the diff/axles to the tailpipe.
In terms of the "bolt up" section, only the dump and cat are usable cross-platform.
  • 1 month later...
