genuine honest person Member 2,769 Member For: 10y 3m Gender: Male Location: near brisbane Posted 30/01/15 11:50 AM Share Posted 30/01/15 11:50 AM that is correct ,they are not under pressure like a front spring Link to comment Share on other sites More sharing options...
genuine honest person Member 2,769 Member For: 10y 3m Gender: Male Location: near brisbane Posted 30/01/15 11:52 AM Share Posted 30/01/15 11:52 AM I undone the diff first then the rear shock then the rear shackle Link to comment Share on other sites More sharing options...
(Locky) Member 85 Member For: 10y 3m 25d Gender: Male Posted 30/01/15 11:53 AM Author Share Posted 30/01/15 11:53 AM Confuses as to what removing rear disks has to do with it? Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 15y 9m 11d Gender: Male Location: Perth, Western Australia Posted 30/01/15 12:24 PM Share Posted 30/01/15 12:24 PM (edited) Confuses as to what removing rear disks has to do with it?Good point... it doesn't, unless you're going to do anything with axle bearings (and possibly handbrake adjustment) while you're there.Although, removing the disc rotors might help with getting access to the u-bolt nuts. Edited 30/01/15 12:26 PM by PhilMeUp Link to comment Share on other sites More sharing options...
(Locky) Member 85 Member For: 10y 3m 25d Gender: Male Posted 30/01/15 12:45 PM Author Share Posted 30/01/15 12:45 PM (edited) Nah after reading your walkthrough think rear bearings are one of the few things im actually going to pay labour for in the last few years, too much f*ck around taking something to get pressed for dailyThinking I really should have given king springs a buzz during week to sus out what the strips are for hahaha Edited 30/01/15 12:46 PM by (Locky) Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 15y 9m 11d Gender: Male Location: Perth, Western Australia Posted 30/01/15 01:38 PM Share Posted 30/01/15 01:38 PM Nah after reading your walkthrough think rear bearings are one of the few things im actually going to pay labour for in the last few years, too much f*ck around taking something to get pressed for dailyRemoving and re-fitting axles is extremely easy. I had trouble last year with getting the old bearings off because I didn't have the right stuff to do the job with. I was also trying to use the press for everything so that I could learn to do it late at night (ie no power tools).Last night I tried cutting the collar off an axle with a cutting disc and angle grinder. It was extremely easy to do. I used some mini boltcutters to cut the bearing cage off, and then the press to remove the inner ring from the bearing cage that was left on the axle.If you want to replace the axle bearings while you're at it then get a pair of Timken 2985 bearing kits (around $30 each) and take the axles to a workshop with a press (eg suspension place). At least then you can save on the labour cost of removing the axles and putting them back in.Thinking I really should have given king springs a buzz during week to sus out what the strips are for hahahaI can't see what they're for. For leaf springs, there's one bolt at each end and the u-bolts in the middle to hold the diff in place. Link to comment Share on other sites More sharing options...
(Locky) Member 85 Member For: 10y 3m 25d Gender: Male Posted 31/01/15 04:09 AM Author Share Posted 31/01/15 04:09 AM Well got them in about 3 hoursDidnt go yoo bad besides copping a rotor to the face when diff sprung up after undoing last bolt of first sideThis is about the only place the washers made sense. I guess as the spring packs are slightly different sizes Link to comment Share on other sites More sharing options...
PhilMeUp Member 1,045 Member For: 15y 9m 11d Gender: Male Location: Perth, Western Australia Posted 31/01/15 08:57 AM Share Posted 31/01/15 08:57 AM Didnt go yoo bad besides copping a rotor to the face when diff sprung up after undoing last bolt of first sideSee, I knew there was a good reason somewhere for removing the disc rotors! 1 Link to comment Share on other sites More sharing options...
