  • Member For: 17y 10m 8d
Hi,
I have purchased a Whiteline adjustable rear sway bar and am wanting to know which adjustable bolt point would be best suited for everyday driving to get a better ride. It has 2 bolt holes, which assuming one being soft and the other being hard?
Thanks in advance.
  • Member For: 17y 6m 30d
I run mine on the softer setting ( the one closest to the end of the bar ), as the whiteline is a larger diameter than the stock item (22mm v 19mm from memory) so will be stiffer than oem even on the 'softer' setting.
  • Member For: 12y 9m 11d
I run my rear on the soft setting too. I initially put it on the hard setting but the rear felt like it wanted to overtake the front under very hard braking at the track. Was very unsettled. I then changed it to the soft for the next time out and it was 100% better.
Although just driving around on the street it felt better with the rear bar on hard, just kept the car flatter. But, it was a very different story at the track pushing it.
And I run my front bar on max hard.
Edited by Seaton
