May 24, 201412 yr #1 Bf mk 2 07 I bought the car it had few issues with oil leaks and I have slowly fixed it and now the premium sound screen stop working o the joys. Everything still works, radio, heating or cooling or turning one side to cold and the other heat lol. I held the volume button until it made the beep still nothing also tried to see if the screen would turn on when I volume up on the steering wheel but It didn't but when I start the car the screen flickers here and there. So I would say it something silly in the board has failed. It's would have to be what the screen gets it's feed from has failed.Has anyone pulled apart one to fix one or heard of this issue? But anyways I will probably have go anyways and have screen ready to replace. As I see it's a waste throwing out perfectly good unit just because screen decided to not work. But it's a real sh.. Because I started a new job and the to be likes having the screen work has she uses the GPS. A lot.Or is it worth throwing in the towel and buy replacement!Sent from my iPhone using Tapatalk
September 11, 201412 yr #2 Hey mate same thing happened in my Bf F6. The screen started flicking one day then never came back on. Everything still works fine but just can't see anything. I pulled the icc out and looked to see if anything was unplugged etc but no luck. I just bought another screen so hopefully in the next week or so I'll pull the icc out again and swap screens over and see what happens
September 12, 201412 yr #3 I'd try ASL Automedia first, they repair them and they can give you a changeover unit.
September 16, 201412 yr #4 P-BA-xr6 just letting you know I ripped the icc out and swapped screens over and bingo worked first pop.
