FORDTECH Member 383 Member For: 23y 3m 27d Location: On the edge Posted 04/02/04 05:47 AM Posted 04/02/04 05:47 AM Fordtech ol mate, is this the same as for the Boss 290 as my car stalled a couple of times in the first couple of weeks, when weather was fairly hot, but has'nt done it lately?? :banghead: Redhawk, Being that it's a canister purge issue and your vehicle is fitted with the said device I would have to say Yes.
IM2QIK Member 84 Member For: 22y 10m 5d Posted 04/02/04 06:16 AM Author Posted 04/02/04 06:16 AM Hi FordTech, can you elaborate on the Canister Purge Valve issue for my dealers replaced this twice and it has'nt done anything ..... my car still randomly stalls frequently every second or third day!!! It does'nt make sence??????????????
axw01 Legacy Donating Member 127 Member For: 23y 6m 8d Location: Brisbane QLD Posted 05/02/04 01:27 AM Posted 05/02/04 01:27 AM I agree IM2QIK, I have had the purge valve replaced 3 times now and still have the issue, so this is obviously not the solution. Mine hasn't actually stalled yet, but gets very close and catches itself. This happens very frequently with air on and slowing down / sitting still at lights.............Last time they replaced the purge valve (at 45klms service), the car did show the error code for purge valve...wierdEven wierder, I didn't even have this issue until the beast got around 35000 klms on the clock!
Macktheknife Xtreme Xalted Member Legacy Donating Member 3,112 Member For: 23y 4m 20d Gender: Male Location: BrisVegas Posted 05/02/04 04:59 AM Posted 05/02/04 04:59 AM Lordy Lordy.Have taken to wearing an ugly mask (Stop that sniggering you lot) so that I dont become embarrased in traffic the thing stalls so much.May even have to resort to fitting Expensive Daewoo badges over the blue ovals............
FORDTECH Member 383 Member For: 23y 3m 27d Location: On the edge Posted 05/02/04 07:27 AM Posted 05/02/04 07:27 AM Hi FordTech, can you elaborate on the Canister Purge Valve issue for my dealers replaced this twice and it has'nt done anything ..... my car still randomly stalls frequently every second or third day!!! It does'nt make sence?????????????? The canister purge is controlled by the PCM(Hence the need for different calibrations).Basically if it's not being controlled right they can replace the purge soleniod 100 times and it won't make any difference.Hope this makes sense.
chief Member 166 Member For: 23y 2m 11d Location: Melbourne Posted 05/02/04 07:28 AM Posted 05/02/04 07:28 AM I had my car stall for the second time in 15000k's first time on a hot day with aircon on 'taking off' from the lights. Yesterday with the clutch in while parking wheel was probably on full lock my car is like a july - august build. It seemed yesterday that as soon as the steering hit full lock the computer shut the car down. Started up again with some beeping noise crakin', hasn't done it since. Would have been fairly dangerous if I was doing a u - banger on the highway or something :( Any ideas FORDTECH? Your help would be appreciated, I rang my service dept. and said try to get it to do it again, hasn't happened, but still WTF.
IM2QIK Member 84 Member For: 22y 10m 5d Posted 06/02/04 12:09 AM Author Posted 06/02/04 12:09 AM Thanks for the explanation FordTech ... may I ask how the incorrectly calibrated ECM actually stalls the engine via the Canister Purge Valve Solenoid? What does the Canister Purge Valve do and how does it's incorrect operation create stalling and or idling problems in XR6T's?
FORDTECH Member 383 Member For: 23y 3m 27d Location: On the edge Posted 06/02/04 11:06 PM Posted 06/02/04 11:06 PM Thanks for the explanation FordTech ... may I ask how the incorrectly calibrated ECM actually stalls the engine via the Canister Purge Valve Solenoid? What does the Canister Purge Valve do and how does it's incorrect operation create stalling and or idling problems in XR6T's? The canister purge solenoid is part of the emission control system that deals with the fume's that are produced by the sealed fuel system of most modern vehicles.It's main function is to open when the vehicle is either above a certain speed or certain engine rpm.What happens is the purge solenoid is operating while you are driving along and happily venting the volitile fumes from the fuel system into the inlet manifold so they effectively become part of the air being drawn in(In the case of the T's,Forced in)and burnt in the combustion chamber.Unfortunately some vehicles have been either operating the purge solenoid at the wrong time or keeping the purge valve open all the time.This has been creating quite a few different problems(And a lot of you guys can testify to this)from vehicles starting rich and running rough when first started to vehicles "stalling" or "hunting" at idle.This is why you can normally start the vehicle almost straight after it has stalled or if it starts rough you simply turn it off and it restarts fine.In a nut shell, The PCM controls this little bugger and apparently the new cal's that are to be available soon rectifies this.(Along with 33 new cal's for various other things(and before you ask they're not all for BA's).For your reference the software level your dealer should have that includes all the new cal's is B29.3. If they're not using this and they have told you that they have updated your PCM then they're full of sh*t.
teebone Member 183 Member For: 22y 10m 24d Location: South of Melbourne, near the sea Posted 07/02/04 11:43 AM Posted 07/02/04 11:43 AM For your reference the software level your dealer should have that includes all the new cal's is B29.3. If they're not using this and they have told you that they have updated your PCM then they're full of sh*t.Fordtech, is this cal version for manuals and Autos?
FORDTECH Member 383 Member For: 23y 3m 27d Location: On the edge Posted 07/02/04 11:47 AM Posted 07/02/04 11:47 AM It's for the entire BA range from XT right through to LTD.
