  • Member For: 13y 7m 20d
Hay guys I own a BF typhoon.
As of the last few weeks the engine has been running slightly rougher on idle and doesnt sound too flash on idle ( alot louder than normal)....I have also noticed quiet a loud sound that I similar to that of the induction from the turbo but alot louder and it occurs even when not on boost.
Have not noticed any performance issues or any other problems just its not sounding too healthy. It is due for an oil change and we will be having a closer inspection at the problem as well as doing the change later this week but it still has only been less than 10000 km since the last change.
Any ideas what this sound could be?
  • Hench, but no longer shredded or tanned.
  • Member For: 18y 3m 10d
Probably Cooler pipe is loose, as said above you may have a leak somewhere. Check from the throttle body to the intercooler and back to the turbo for loose clamps split pipes/blown off etc.
