  • Member For: 13y 3m 29d
Hey everyone, I got under my g6et today just to have a look and noticed it has blue airbags within the back springs and has airlines leading next to the towball, I am just wondering what these should be set at psi wise (I don't do any towing at all), also I am planning on getting sssl springs in the back fairly soon and wondering how they will affect the bags? I don't really have a need for them. If I do get them removed is there much involved?
Cheers
Edited by underoath123
https://www.fordxr6turbo.com/forum/topic/85738-g6et-airbags/
  • Member For: 14y 8m 17d
They would have been fitted to help level the rear when loaded up and towing. It's something I've been considering for my XR6T instead of literally dragging the arse of it through the ground/rocks haha.
Not 100% but I think they only need low pressure to keep shape when not being used to bear load. If you're going SSSL springs you'll probably have to remove them. They're probably the firestone ones, and they do have normal and lowered models so I'd say that they wont work properly with SSSL springs. They should be easy to remove, once deflated should fit out between the springs, but if the springs are coming out it's obviously a non issue anyways.
If you do get rid of them and they are 100% working and in good nick still let us know as could be interested (they're not expensive new though mind you)
