Problem Starting Car When Warm
Featured Replies
#1
Hi, I having a problem starting ba 2004 turbo when warm. When cold I have no problem. Car starts, drives, all ok. Then when I turn it off and try to start it again, it starts then low revs, then it turns off. I need to press the accelerator to hold the revs, then put it in drive. I have replaced the TPS and cleaned the TB, I have new plugs and coils and a new battery!
Any help would be great!!
Thanks
Mark
#2
Does it crank slow when hot?
#3
Might be running excessively lean on the open loop start, you just have to find out why.
#4
Starter motor shouldn't be a issue as the car IS starting then idling low.
Perhaps your pump is on the way out. Once the pump is warm and sits in the warm fuel it may fail to flow enough.
Or as toads said. Sounds fuel related to me...
Does your car have any mods? Flash tuned?
#5
starter motor can cause it as slow cranking speed can lead to a stall, territorys are bad for that, same starter etc so dont ask me why, could be calibration related. also early key release can do it
#6
  • Author
Thanks, car has no mods. I will have to check the fuel pump and injectors. Don't think it's the starter as it starts then stalls in 1 to 2 secs. Sometimes it's ok, no problems and other times I have to start it 5 times!
Recently Browsing 0
