Robos F6 Donating Members 407 Member For: 16y 3m 10d Gender: Male Location: Vic Posted 25/11/12 10:53 AM Share Posted 25/11/12 10:53 AM Im replacing my leaking sleeve on my ZF. Pulled the pan, dropped the oil and pulled the white locking tab down and removed the sleeve, quite easy.Problem is I cannot get the locking tab back up. I've tried everything. I've tried it with the sleeve in or out but the locking tab doesnt want to budge and move up. It appears its locked out or maybe I pulled it to far down. Any suggestions? Link to comment https://www.fordxr6turbo.com/forum/topic/82985-zf-sleeve-replacement-problem/ Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 10m 16d Gender: Male Posted 25/11/12 11:16 AM Share Posted 25/11/12 11:16 AM You have to be very careful, wiggle the sleeve as you push up eventually it will go up, do not hit or lever it as it will brake and make it impossible to get back down again. Need major patience Link to comment https://www.fordxr6turbo.com/forum/topic/82985-zf-sleeve-replacement-problem/#findComment-1330035 Share on other sites More sharing options...
Robos F6 Donating Members 407 Member For: 16y 3m 10d Gender: Male Location: Vic Posted 25/11/12 11:43 AM Author Share Posted 25/11/12 11:43 AM Just for a test, will the tab go up without the sleave in place as that doesnt work either Link to comment https://www.fordxr6turbo.com/forum/topic/82985-zf-sleeve-replacement-problem/#findComment-1330045 Share on other sites More sharing options...
bionicxr6t05 Bronze Donating Members 2,216 Member For: 13y 10m 16d Gender: Male Posted 25/11/12 11:51 AM Share Posted 25/11/12 11:51 AM Theres a little locater I think you need to press Link to comment https://www.fordxr6turbo.com/forum/topic/82985-zf-sleeve-replacement-problem/#findComment-1330048 Share on other sites More sharing options...
