ripbt1 New Member 12 Member For: 15y 18d Posted 04/09/12 06:02 AM Posted 04/09/12 06:02 AM (edited) I just finished my install of a shift light seeing as a few people want to do the same but are having issues so I thought I would put it up.http://www.jaycar.co...ch&form=KEYWORDI bought a frequency switch from jay car, YOU HAVE TO SOLDER THE KIT TOGETHER p.s get the ub3 box also its on the receipt $5the kit has an LED on it which you can use as a shift light, but if you do I recommend buying a much brighter one.This also is very good because the LED is tiny so you can hide it easily and still have the stock look.I used an old adjustable speco shift light with a 12v globe in it, I chopped all the wires in the shift light (don't need them anymore the frequency switch turns the light in and off) and soldered the power from the relay on the frequency switch board directly to the pins on the globe.the circuit works by detecting the pulses from a sensor you choose (I used the cyl 1 injector because of easy access, brownwire) and by adjusting the pots on the board you set the rpm you want the frequency switch to activate the light Edited 04/09/12 06:04 AM by ripbt1 1
