Silver G6ET Member 23 Member For: 12y 10m 15d Posted 15/08/12 04:58 AM Share Posted 15/08/12 04:58 AM Guys, I just had new xforce 4" all the way through put on. Car is bit grumpy about it. I'm a newbie to modding cars so can someone explain what is happening, what the solution is and idea of cost. ? I'm Sydney based if contacts are recommended. Thanks for your help. Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/ Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 6m Gender: Male Location: SE Melbourne Posted 15/08/12 04:59 AM Share Posted 15/08/12 04:59 AM Any exhaust changes after the turbo will need a retune. You car would be overboosting. The limp mode would be boost cut.you need to get it to a tuner asap and drive off boost in the meantime. Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/#findComment-1279634 Share on other sites More sharing options...
wa g6et Member 657 Member For: 13y 11m 19d Gender: Male Location: Perth NOR Posted 15/08/12 05:07 AM Share Posted 15/08/12 05:07 AM Can't believe they didn't advise you. Did you get the full 4" system or 4" dump/cat into 3.5" rear?Even with a tune you might need to do the wastegate mod(makes the wastegate port larger to allow the ECU to bypass more exhaust gases and control boost easier) as FGs can have boost control issues with the bigger dump and high flow cat.See a recommended tuner in your area, they will help with costs. Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/#findComment-1279642 Share on other sites More sharing options...
Silver G6ET Member 23 Member For: 12y 10m 15d Posted 15/08/12 05:10 AM Author Share Posted 15/08/12 05:10 AM Ok, cheers paulie Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/#findComment-1279644 Share on other sites More sharing options...
Silver G6ET Member 23 Member For: 12y 10m 15d Posted 15/08/12 05:11 AM Author Share Posted 15/08/12 05:11 AM Full 4". Will book in tune ASAP. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/#findComment-1279645 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 9m 12d Gender: Male Posted 15/08/12 06:31 AM Share Posted 15/08/12 06:31 AM Full 4". Will book in tune ASAP.Just don't let those two words " in tune " have anything to do with your tuning! Research and find a good tuner!!!! Plenty of reputable tuners in Sydney! Except for the above mentioned one :/ 3 Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/#findComment-1279673 Share on other sites More sharing options...
Silver G6ET Member 23 Member For: 12y 10m 15d Posted 30/08/12 12:21 PM Author Share Posted 30/08/12 12:21 PM Went to crescent Motorsport and got this sorted out. 1 Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/#findComment-1287635 Share on other sites More sharing options...
Kosij Donating Members 2,045 Member For: 13y 9m 12d Gender: Male Posted 30/08/12 01:57 PM Share Posted 30/08/12 01:57 PM What was the outcome? Did you get a dyno tune? Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/#findComment-1287656 Share on other sites More sharing options...
BAR61R New Member 15 Member For: 13y 3m 11d Gender: Male Location: sydney parramatta Posted 31/08/12 08:02 AM Share Posted 31/08/12 08:02 AM Where u buy that exhaust and how much Link to comment https://www.fordxr6turbo.com/forum/topic/81462-car-going-into-limp-mode-after-exhaust-install/#findComment-1288022 Share on other sites More sharing options...
