Rancidpunx Brisbanes Resident Detailer Donating Members 950 Member For: 15y 3m 7d Gender: Male Location: In my Cabin Outside Brisbane. Posted 23/05/12 07:53 PM Share Posted 23/05/12 07:53 PM You run your aftermarket headunit on the AUX setting for the ICC. Everything still works on the ICC as normal with AUX displayed on the screen. Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 18y 5m 23d Gender: Male Location: Muswellbrook,NSW Posted 24/05/12 08:50 AM Share Posted 24/05/12 08:50 AM fit it up to the tissue box (fitting kits available)use the Aux in of the head unit to feed the ICC sound to the HU if/when required Link to comment Share on other sites More sharing options...
sam_rigger Member 246 Member For: 13y 3m 12d Posted 31/05/12 10:36 AM Share Posted 31/05/12 10:36 AM I'm confused. So does that mean using the AUX to feed the head unit, you can still use the ICC's radio (for example) and get sound? I thought the headunit would bypass everything..... Link to comment Share on other sites More sharing options...
sam_rigger Member 246 Member For: 13y 3m 12d Posted 31/05/12 10:37 AM Share Posted 31/05/12 10:37 AM so would the steering wheel controls work if using 'aux' to power the head unit? Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 18y 5m 23d Gender: Male Location: Muswellbrook,NSW Posted 31/05/12 01:03 PM Share Posted 31/05/12 01:03 PM Using the ICC Audi out fed into the aux in of the aftermarket hu. U could still use the factory ICC if when required. Steering wheel controls can be set up to control aftermarket hu. 2 company's make interface kits. PAC audio. And cat10. They take the wheel controls and control the aftermarket hu. Link to comment Share on other sites More sharing options...
The Jizard GONE FULL WIZARD Donating Members 1,617 Member For: 15y 3m 21d Gender: Male Location: 720 East Kensington Road Posted 01/06/12 03:43 AM Share Posted 01/06/12 03:43 AM (edited) Sorry didn't read above post properly, IMO it is much easier just to install a stand alone aftermarket system in to the car rather than using the ICC. Edited 01/06/12 03:45 AM by Foon Link to comment Share on other sites More sharing options...
quadie Donating Members 720 Member For: 18y 5m 23d Gender: Male Location: Muswellbrook,NSW Posted 01/06/12 07:20 AM Share Posted 01/06/12 07:20 AM best to do that but while your there hook the icc up to the sftermarket unit , u never know when u will want to use the icc for something Link to comment Share on other sites More sharing options...
The Jizard GONE FULL WIZARD Donating Members 1,617 Member For: 15y 3m 21d Gender: Male Location: 720 East Kensington Road Posted 01/06/12 07:24 AM Share Posted 01/06/12 07:24 AM 3 years since I did my setup and haven't needed the ICC once Link to comment Share on other sites More sharing options...
sam_rigger Member 246 Member For: 13y 3m 12d Posted 02/06/12 01:40 AM Share Posted 02/06/12 01:40 AM so the ICC still turns on and all that, just has no volume basically?I'm weighing up taking out the AMP and just running the type r's off the ICC, or putting in an aftermarket headunit. Still undecided. Ute is still at the panel beater being repaired after some bitch rammed the car behind me, and I was therefore hit after that. Damn annoying! Link to comment Share on other sites More sharing options...
The Jizard GONE FULL WIZARD Donating Members 1,617 Member For: 15y 3m 21d Gender: Male Location: 720 East Kensington Road Posted 02/06/12 04:09 AM Share Posted 02/06/12 04:09 AM so the ICC still turns on and all that, just has no volume basically?I'm weighing up taking out the AMP and just running the type r's off the ICC, or putting in an aftermarket headunit. Still undecided. Ute is still at the panel beater being repaired after some bitch rammed the car behind me, and I was therefore hit after that. Damn annoying!Basically yes the ICC works but with no volume. Link to comment Share on other sites More sharing options...
