Stalling
Featured Replies
#1
:finger:
Hi all.
Going down the freeway yesterday at 80kph and the car began to surge for about a klm then settled down.
This morning on the way to work (yuk) I gave it a mild bootful it coughed a little made some loud induction noise then stalled at the stop sign. Started again , although it sounded like it was running on 3 cylinders, thought oh f#ck, turned it off and then it started perfectly. Wonderd if it had anything to do with the BOV or wastegate actuator. Running 411cc injectors and 10lb of boost, but was not hammering the car. Got to the freeway on ramp and it flew straight to 230kph smooth as a whistle and is still running fine. Any Ideas? :thumbsup:
#2
I think you've got a drama in the making hypnodoc.
Scotty
#3
I've had very occassional surging in 3rd gear while in SSS mode, but not the other stuff you mention.
#4
  • Author
Scotty
:spit:
Ew, Very Scary, sounds like the computer selected limp mode for some reason. It's in at the dealer for driveshaft balance momday, I'll get them to check the codes. At least it came good, maybe the unichip needs some fine tuning :spit:
#5
doc
could it still be something to do with the last problems you had with the loose wire or something.
#6
  • Author
doc
:unsure: Must have been just a little glitch, hasn't hapened since fingers crossed :ta:
Recently Browsing 0
