08/04/12 08:09 AM08/04/12 08:09 AM #11 I have a BA mk ii tubo. plan on getting it modded. so far have intercooler upgrade,typhoon CAI, atomic valve springs,4" dump pipe, full system with high flow cat,hks sequenttial bov. when I get these items installed and 10psi boost and tuned I amj thinking should get the trasmission beefed up to.will install trascooler as well. the auto is great now shifts seamlessly-94k kms on the clock. anyone tried this kit?http://www.autotechengineering.com.au/Ford/Transmission_upgrades.htmlIncreasing power to any transmission will ultimately require you to increase the strength of that transmission. Whether automatic or manual, transmissions have their limits and when referring to the massive untapped power of the Ford XR6 Turbo and FPV Typhoon and Tornado, you'll need to plan some modifications to ensure things move smoothly in your gearbox. Customers may also wish to increase the size of their stall converter for street or racing use. Our packages can cater for all your requirements. For customers with manual transmissions, Autotech have a range of clutch upgrades that will ensure increased power levels flow smoothly to the wheels. Autotech have a variety of solutions for the Falcon series of cars including automatic transmission modifications, clutches and even replacement gearboxes. This package is suited to the BA Falcon 4 speed automatic and consists of valve body modification to increase the speed and firmness of the automatic transmission gear shift and an oil cooler for the transmission. This package is aimed at 4 speed owners who choose power levels up to 360kw. This package is suited to the BA Falcon 4 speed automatic transmission and consists of a full automatic transmission rebuild and a 2800rpm stall converter. The upgrade includes replacement of all clutches and bands in the transmission along with other parts to enable the automatic transmission to handle power levels above 350rwkw. The transmission also received an oil cooler and has its valve body modified to ensure firmer shifts under hard acceleration. If you would like more information on these transmission packages for the Ford and FPV range of Vehicles, please e-mail or phone Autotech. am thinking stage one. any ideas please?
08/04/12 10:53 AM08/04/12 10:53 AM #12 MV do good work. they make race transmissions..$2800 does sound cheap though.
