  • Member For: 15y 4m 27d
Posted (edited)
Ok, so I have replaced the turbo cartridge with a MR Turbo one, now under boost at 3500rpm in 4th the car shudders and looses power.
So today I tested it out after a few adjustments and hit 4th at 3500rpm and the car severley lost power, kinda like chug chug chug back home (1 minute drive), then I popped the bonnet and there was coolant jamming its way back into the resevoir under some type of pressure. There was also a knock in the what sounded like the engine, but from the side of the car also sounded as if it was from the gearbox.
Sat the car for 1 and half hours, then fired it up, no knocking noise and coolant was back to normal, took it for a light drive, it seems ok but I know the problem still remains, if I boost it up it's gonna pop for sure.
Any idea's.
p.s. I am taking it to a mechanic to check it out, definitely to Ford to run the diagnostics.
Edited by XR6Turbosonator
  • Legacy Donating Member
  • Member For: 18y 8m 22d
Posted
car blew up then the onboard computer fixed it. simple.
  • Member For: 15y 6m 12d
Posted
are you serious? if a piston cracked I doubt the computer could fix it.
:spit:
  • 3 weeks later...
