  • Member For: 13y 10m 3d
Hi All
Thought I'd say hi as I've just joined up, I have a problem I have a BA xr6 Turbo which I've owned for 2 years it has been an great car
and I have had absolutely no trouble with it UNTIL NOW ! I have just blown the Turbo so my question is if I was to take the turbo off is it possible to still drive
the car day to day?, would it still drive like a non turbo xr6? the only reason I ask is at the moment I don't have the money to replace the turbo
but if I can still drive to work etc etc until I can afford one I will do that.
Sorry but I don't know a lot about motors and stuff if you could give me some advice I would really appreciate it !
Cheers
https://www.fordxr6turbo.com/forum/topic/76333-blown-my-turbo/
  • Replies 20
  • Member For: 13y 10m 9d
just blew mine recently.. real gravel sound, no you can't really use without turbo compression and all that.. took mine to mech and got a new turbo core from ebay for $880,, as long as turbo housing ok . have had car back for 2 weeks makes more noise than it used to but have had no probs..
Wouldn't drive at all bits in the turbo flying about can't be good.. get earls oil filter as seems to be the fix.
wish I knew that in first place!
Edited by Rensta
Apart from the turbo what is the differance between a normal xr6 motor and a turbo xr6 motor does the turbo motor have higher compression?
the only reason I ask is I have blown the turbo in my BA and at the moment I can't afford to fix it but I was wondering if it possible to take
the turbo off and will it drive like a normal xr6 motor? If you could give me some info on this it would be really appreciated.
Thanks.
  • Member For: 18y 8m 11d
You prob could but you'll need to change the exhaust,, airbox setup. Prob run like crap due to the turbo motor having lower compression and might also throw codes and go limp mode.. That's just my opinion though but sure Mick would know better
  • BOOST
  • Moderating Team
  • Member For: 21y 9m 3d
Ive merged the topics so there is only one now, hence the reason why its here. If you want to speak to him direclty send him a PM.
  • Member For: 18y 4m 24d
If you pull the turbo out you would have to connect up the inlet and outlet water and oil lines other wise fluids would go everywhere. Just be patient my car has been off the road since April last year, pull the turbo out yourself save alot in labour.
