Periklis Member 67 Member For: 14y 9m 4d Posted 15/06/11 06:34 AM Share Posted 15/06/11 06:34 AM Hey guys,Just bought a XR6T its a Nov 02 BA, 5 speed manual, havent done any work to it, except over the weekend I put on a dose pipe on it. (Please don't go on about the dose pipe, as it was my decision and I like the sound, and dont beleive any of that crap that it ruins your turbo). Anyway after putting on the dose pipe I have noticed a big loss in power, and when I hit boost, its asif the rev limiter kicks in early and I hear loud popping, before the rev limiter comes into full swing.I'm not too sure what this may be but if anyone can give any input that would be greatly apreciated,Thanks,P Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/ Share on other sites More sharing options...
velocityxr6t Member 122 Member For: 16y 6m 1d Gender: Male Posted 15/06/11 07:17 AM Share Posted 15/06/11 07:17 AM (edited) Compressor surge doesn't shorten the life of a turbo? In that case the guy who invented the bov to prevent it pulled a sweet scam and made a butload of money off it. If only you where around to save us from this folly.Now to try and be helpful, normally if you work on a car then something is wrong afterwards it's something you did. Recheck your work, make sure all electrical plugs are reconected, any vacuum hoses and stuff like that. Edited 15/06/11 07:20 AM by velocityxr6t Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1114460 Share on other sites More sharing options...
spoolxr6 Member 312 Member For: 14y 5m 29d Posted 15/06/11 07:52 AM Share Posted 15/06/11 07:52 AM could be flowing more air now and the ecu hasn't been tuned for this. Also just try regapping your plugs to about .8mm. Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1114467 Share on other sites More sharing options...
Mr_4.0 Member 1,096 Member For: 14y 3m 25d Posted 15/06/11 08:16 AM Share Posted 15/06/11 08:16 AM I'd say it's got to do with the extra hot intake temps your now getting. That with a little more flow through the intake. Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1114473 Share on other sites More sharing options...
Periklis Member 67 Member For: 14y 9m 4d Posted 20/06/11 05:53 AM Author Share Posted 20/06/11 05:53 AM I assumed it had something to do with the ECU as the air intake is all over the place and the computer has no idea what is happening? Am I wrong by saying this? Just using common sense as I dont know too much about these sort of things. Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1115806 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 21d Gender: Male Location: Perth Posted 20/06/11 06:10 AM Share Posted 20/06/11 06:10 AM I'd say while you where fitting your dose pipe you knocked one of the boost solenoid hoses off..... Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1115809 Share on other sites More sharing options...
Periklis Member 67 Member For: 14y 9m 4d Posted 22/06/11 11:27 AM Author Share Posted 22/06/11 11:27 AM where are the boost solenoid hoses located at? Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1116521 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 7m 21d Gender: Male Location: Perth Posted 22/06/11 11:31 AM Share Posted 22/06/11 11:31 AM just under your dose pipe..... Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1116524 Share on other sites More sharing options...
Periklis Member 67 Member For: 14y 9m 4d Posted 22/06/11 11:36 AM Author Share Posted 22/06/11 11:36 AM thanks mate - I'll have to take a look, Ive taken the pipe off for now until I get to the bottom of the problem. My old man reckons the computer is out of wack and all the air flow is freaking out the ecu. After I get the mods I want done I'm going to get it tuned. Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1116529 Share on other sites More sharing options...
Periklis Member 67 Member For: 14y 9m 4d Posted 27/06/11 04:41 AM Author Share Posted 27/06/11 04:41 AM Boost solenoid is fine, sprayed some degreaser in while I was there. Anyone else have any idea? I really want a full continuous boost back. The boost just kind of cuts on and off until it hits the limiter, and if I push it real hard puffs of black smoke come out the exhaust as I shift from first to second. Link to comment https://www.fordxr6turbo.com/forum/topic/75340-xr6t-loosing-power-just-before-rev-limiter/#findComment-1117896 Share on other sites More sharing options...
