  • Menace
  • Member For: 14y 24d
Hi all,
I would like to make a new intake under the headlight to a pod on my BF after fitting up the new cooler.
I was hoping to use the following materials starting from the turbo to the pod only.
* 3" to 3.5" reducer 45 degree
* short piece of 3.5" alloy pipe
* 3.5" 45 degree bend
* 3.5" 90degree bend
* Pod filter 3.5" hole 6 inch long
I have read that the battery tray may need some trimming to fit the pipe under neath but will the 3.5" pipe fit underneath the headlight?
Is that all the materails that is needed or am I missing a a small bend somewhere?
Is it really worth stepping up to the 3.5" from the 3" all the way as I believe the 3" doesnt involve any cutting of the battery tray?
Cheers
https://www.fordxr6turbo.com/forum/topic/75040-intake-under-battery/
  • Menace
To correct my last sentence after searching I have found that the 3" pipe does involve some of the battery tray to be trimmed aswell
  • Member For: 20y 8m 7d
the 3.5 wont fit without a huge headache, even the 3' JUST fits.. most BA/BF headlight on the drivers side still sit up a little once a bigger UBP is fitted..
  • Menace
far enough I think I'll stick with the 3". I took the front bar off tongiht and checked out what clearance I had. I can see that I will need to trim a small part of the battery tray to get a smooth run through.
Still a little unsure if I have the right materials list to do it though, even if I do change it all to 3"...?
On another note I was just doing a little test fit of the 600x300x76 cooler and I can see why people seem to fit the cooler to the left an inch due to the connection fitted to the condensor itself on the passenger side that sticks out.. looks like im going to have to take what I can from the front bar and reweld it since the seam weld will be gone near each end of the cooler.
The cooler should "just" fit but its going to be extremely tight. The other A/c line that's in the way had to be bent up a rediculous amount to stay out of the way for the future fitting. Just trying to get everything ready for fitting at this point in time.
  • 1 month later...
  • Menace
Yeah bud I did it all in 3 inch but I had to holesaw a 90mm hole just in front of the battery for the elbow to a pod coz the 3 inch won't get under the headlight good. Had to cut the back of the battery tray out too.
I needed 2 45's and a 90
