scorpa1 Member 5 Member For: 15y 5m 7d Posted 26/04/11 08:29 AM Share Posted 26/04/11 08:29 AM (edited) ok, BA xr6t 2003 uteall of a sudden keyless entry remote will not workreplaced battery.. didnt worktryed to reprogram, wouldnt.... purchased new remote fob and tryed to reprogram... nopetryed to reprogram both.. key to acc, rear demister 3x, door locks or unlocks, not lock and unlock, is this correct?push button on remote, no responce no matter what I doturn key off door eaither locks or unlocks depending on if I start with doors locked or unlocked.no responcethis just happerned randomlyHELP!!Cheers Edited 26/04/11 08:31 AM by scorpa1 Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/ Share on other sites More sharing options...
Wenier Donating Members 1,736 Member For: 15y 5m 29d Gender: Male Location: Christchurch, New Zealand Posted 26/04/11 06:40 PM Share Posted 26/04/11 06:40 PM so after you do the key and demister bit is it doing what is written in the book with the door locks. Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/#findComment-1100405 Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 5m 12d Gender: Male Location: Perth, WA Posted 29/04/11 06:58 AM Share Posted 29/04/11 06:58 AM I just did mine today mate,I followed this write-up (Most are written in a similar fashion, but I had a few dramas and this one worked for me)http://www.fordforums.com.au/showthread.php?t=11227133Turn the key 1 click from off.Then press the rear demist button 3 times in under 5 seconds (1 a second is fine - too fast doesn't work)Just follow the rest If you have any dramas let me know mate,Dan Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/#findComment-1101131 Share on other sites More sharing options...
scorpa1 Member 5 Member For: 15y 5m 7d Posted 11/05/11 08:47 AM Author Share Posted 11/05/11 08:47 AM I just did mine today mate,I followed this write-up (Most are written in a similar fashion, but I had a few dramas and this one worked for me)http://www.fordforums.com.au/showthread.php?t=11227133Turn the key 1 click from off.Then press the rear demist button 3 times in under 5 seconds (1 a second is fine - too fast doesn't work)Just follow the rest If you have any dramas let me know mate,Dan Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/#findComment-1105022 Share on other sites More sharing options...
scorpa1 Member 5 Member For: 15y 5m 7d Posted 11/05/11 08:49 AM Author Share Posted 11/05/11 08:49 AM (edited) Cheers for the reply, well if the door locks are ment to lock and then unlock.. NO my door will just lock, is this correct? so fron the start: in car doors closed and unlocked, key to acc, demister 3X, doors will lock only,... not lock then unlock, is this correct?cheersrob Edited 11/05/11 08:55 AM by scorpa1 Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/#findComment-1105023 Share on other sites More sharing options...
NVT Formerly EGOBFXR6 Donating Members 1,111 Member For: 17y 5m 12d Gender: Male Location: Perth, WA Posted 11/05/11 12:12 PM Share Posted 11/05/11 12:12 PM Hey Rob,Yep, the car will lock. When it does, you press a button on the remote and the doors will then open (I pressed the lock button even though it was already locked). Turn the car off and remove the keys and you're good as done.So, in short.Jump in carPut keys in ignitionTurn 1 click onPress rear demister 3x - 1 time per seconddoors will lockpress any button on remotedoors will unlockturn ignition to off and remove keyscheck to see if remote worksDone Hope it works for you mate,Dan Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/#findComment-1105115 Share on other sites More sharing options...
scorpa1 Member 5 Member For: 15y 5m 7d Posted 12/05/11 05:50 AM Author Share Posted 12/05/11 05:50 AM Hey Rob,Yep, the car will lock. When it does, you press a button on the remote and the doors will then open (I pressed the lock button even though it was already locked). Turn the car off and remove the keys and you're good as done.So, in short.Jump in carPut keys in ignitionTurn 1 click onPress rear demister 3x - 1 time per seconddoors will lockpress any button on remotedoors will unlockturn ignition to off and remove keyscheck to see if remote worksDone Hope it works for you mate,Dan Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/#findComment-1105300 Share on other sites More sharing options...
scorpa1 Member 5 Member For: 15y 5m 7d Posted 12/05/11 05:56 AM Author Share Posted 12/05/11 05:56 AM (edited) cheers for the reply danI get as far as...Jump in car Put keys in ignition Turn 1 click on Press rear demister 3x - 1 time per second doors will lock press any button on remotenothing responds to my remotes, have 2, 1 new 1 with new batteryturn key off, doors unlockremotes do not work.have changed reciever in top of icc, what should I do from here, I do not want to take it to ford!replace BCM?I have inspected door lock actuator, ford reccomended this as they belived the bcu is not geting a signal that the door has locked??cheersrob Edited 12/05/11 05:59 AM by scorpa1 Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/#findComment-1105303 Share on other sites More sharing options...
UBA Donating Members 212 Member For: 13y 6m 26d Gender: Male Posted 06/05/12 12:32 PM Share Posted 06/05/12 12:32 PM sometimes there is too many keys programmed into the ecu, you may need to delete a few and go from there. Link to comment https://www.fordxr6turbo.com/forum/topic/74515-key-remote-wont-reprogram/#findComment-1232901 Share on other sites More sharing options...
