  • Member For: 16y 3m 16d
Hi Kybus
I assume you have a FG Manual?
Mate I am no expert but the only way I no of is through a Tuner, mine said he could turn off all together or change the RPM which I have done.
Edited by RHR
No need to quote above post. USE FAST REPLY
  • It's not a MKI!
  • Member For: 16y 10m 17d
I'd be asking why your car is only making 2700rpm using launch assist when it is supposed to be around 3500rpm.:dontknow:
The only way to get rid of it is to manually bypass the switch on the clutch pedal, or have it tuned out.
