Gonz Member 108 Member For: 13y 2m 30d Gender: Male Location: Perth Posted 05/02/11 01:26 PM Share Posted 05/02/11 01:26 PM Hi,Just wondering if the Auto switched fitted in sedans can be retro fitted to the switch base of a ute? I figure if I buy a sedan switch assembly and remove the two rear window switches it will work as long as the diamentions to fit back into the bezzel is the same and the wiring plug at the bottom? anyone know if this can be done, im not liking not having Auto windows in my ute!cheers in advance,Gonz. Link to comment Share on other sites More sharing options...
unclewal Donating Members 583 Member For: 13y 7m 9d Posted 05/02/11 02:25 PM Share Posted 05/02/11 02:25 PM Im pretty sure its more than just the switch box, I believe you require a pressure sensitive actuator to stop the window when it hits the top of the rail and also incase someone has got their hand/head in the window. Link to comment Share on other sites More sharing options...
foxtrot Member 77 Member For: 15y 6m 20d Posted 05/02/11 08:09 PM Share Posted 05/02/11 08:09 PM Hi. I believe it is possible, the man to contact is ORSMBA (Matt)on this forum or you can fit a Viper 2 door window lift module (dei 530 t) and get one touch windows both up and down and window lift on locking. Cheers MD Link to comment Share on other sites More sharing options...
ORSMBA ORSM Ford Cruisers! Donating Members 319 Member For: 18y 10m 29d Gender: Male Location: Melbourne Posted 06/02/11 04:43 AM Share Posted 06/02/11 04:43 AM Yeah it will work, just put the sedan internals into the ute switch and it will work fine.Matt Link to comment Share on other sites More sharing options...
