  • Member For: 17y 5m 14d
Cat,pump,injectors,springs and tune are your best bet for first round of mods. Should net you around 300rwkw. Then cooler,exhaust,wastegate and retune later on. The less tunes the better on the wallet so plan wisely. Oh and chuck a cooler thermostat in it too.
Edited by ebxmple
  • 570Nm @1800rpm
  • Member For: 21y 9m 22d
Cat and fuel pump aint needed but nice to have
This might be the case for BF's and FG's with low kms etc. Looks like the OP has a BA and I can tell you from experience that I would not take the risk of running around on a stock OEM fuel pump that is 7 or 8 years old, the intank filter probably looks like a ball of mud. Plus the OEM cat is more then likely shagged as well and as soon as it disintegrates the car will boost spike.
xr6t 4.0, you will also need a new set of plug with smaller gaps. Get something like a gas or F6 plug that is gaped to 0.7-0.8mm. Also thinks like new fuel filter and general service etc.
  • Talks Cheap, Let's Race
  • Member For: 18y 7m 29d
Hi xr6t 4.0, here is what I did to my falcon to get 300rwkw
Nizpro modified factory injectors
Nizpro valve springs
x-force hiflow 100cpi cat 4 1/2 body 3 1/2 outlets
82 Deg thermostat
monzer cooler
rapid hot side piping
15 psi actuator on turbo
K&N filter
F6 Cold air intake mod.
Rest of the car is stock including exhaust ( Still has both factory mufflers in it) and fuel pump.
  • Member For: 17y 3m 24d
Me and j.d have done cat/injectors/tune with thermostat and plugs and air filters, and both got over 300. Mine has centre muffler out but j.d's doesn't.
Those prices *Beep* for 968s are what I've seen then sell for at work shops. If the op only wants 250-300 then you would go with the 968s as they are a better injector than the seimons, hub obviously don flow as much.
Fuel pump, I thought the herrod bolt in one was around 500?
But you are the expert on reaching your goal the cheapest way,'so you'ld know :beerchug:
  • Member For: 15y 10m 29d
Hi guys thanks for all the replies.
I thought it was strange as I can remember the group buy for the walbros for like $159. I thought to myself they have to be different O_O
So I could basically get the 300kw I want for less then $3500? :o
Those prices were through chiptourque in queensland btw.
So Cat,pump,injectors,springs, pump, tune, monza or the likes cooler and gapped plugs would be fine?
Whats that then,
Cat - 400? no idea
Injectors $330
Springs installed - 1300 ish
pump - 253
My old tuner recommend the sniper tune. Was alot cheaper too, $700
cooler - 350
plugs - <150
Total - 3483
Am I heading in the right direction now boys? =D
Can anyone recommend a place in brisbane to get all this done where I wont get shafted?
Are the prices I have listed reasonable? I just need to get it all passed by the wifie before I get the go ahead :P
Thanks again,
Todd.
Edit: Lets just say Ill only go for 250 ish.
Injectors, tune, cat and pump?
Edited by xr6t 4.0
$400 is about right for cat by the time you have it installed, but $1300 is a bit steep for v/springs. I paid $850 at what I thought was an expensive workshop.
I wouldn't bother with the sh*tty monza cooler. Either spend the $700 on a hdi or save your money and do a better cooler down the track.
But the 3500 will easily get you there.
  • 570Nm @1800rpm
Ring up Chris from Rapid, he still has the cats for about $160 + postage. It should not cost you more than $100 to have it welded in, so about ~$300 all up.
Valve spring cost about $300 for a set (Nizpro) and it takes about 4-5hrs to fit them, $1300 is very very steep, should be more like $400-500 for labor.
