Toecutter Member 182 Member For: 18y 1m 22d Gender: Male Location: Melbourne Posted 08/11/10 07:10 AM Share Posted 08/11/10 07:10 AM Hey guys, I am having an occasional problem in my XRT.02 BA xrt, aftermarket cooler, valve springs, CAI and tune.Every once and a while when I start my car and change from PARK to REVERSE or DRIVE, the whole car violently shakes and the revs drop and sounds like it's about to stall. I try to put it back to PARK and it continues with it's nonsense. I quickly turn it off and when I restart it, everything is fine.It has done it a handfull of times and only does it a couple of times per week, completely random.It has been running a bit rough lately, sounds like a miss on idle, but cruises fine.I recently replaced the coils too, hasn't fixed it.Trying to fix it all up to sell it!Any help appreciated, thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/ Share on other sites More sharing options...
Kv! Donating Members 1,132 Member For: 15y 5m 2d Gender: Male Location: Eastern Suburbs, Melbourne Posted 08/11/10 07:23 AM Share Posted 08/11/10 07:23 AM Change the oil ? Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1053988 Share on other sites More sharing options...
Toecutter Member 182 Member For: 18y 1m 22d Gender: Male Location: Melbourne Posted 08/11/10 07:31 AM Author Share Posted 08/11/10 07:31 AM Are you suggesting I change the oil, or asking if I have? haha.I have had the car serviced about 2000k's ago.. New oil. Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1053989 Share on other sites More sharing options...
Banned1 Banned Banned 734 Member For: 14y 10m 6d Gender: Male Location: Caloundra Posted 08/11/10 08:00 AM Share Posted 08/11/10 08:00 AM (edited) did you change the gearbox oil ? had an issue similar years ago, was the TPS acting up ! Edited 08/11/10 08:01 AM by rab Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1054006 Share on other sites More sharing options...
ARVO Member 141 Member For: 16y 8m 24d Gender: Male Posted 08/11/10 08:28 AM Share Posted 08/11/10 08:28 AM Try your o2 sensor mate Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1054025 Share on other sites More sharing options...
Banned1 Banned Banned 734 Member For: 14y 10m 6d Gender: Male Location: Caloundra Posted 08/11/10 08:51 AM Share Posted 08/11/10 08:51 AM will the car log fault codes ?? check those ? Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1054039 Share on other sites More sharing options...
Toecutter Member 182 Member For: 18y 1m 22d Gender: Male Location: Melbourne Posted 08/11/10 09:24 AM Author Share Posted 08/11/10 09:24 AM Thanks for the reply guys.After the last service my mechanic did say that the air/fuel mix was showing way out on his computer, I just put it down to having a big induction system and bigger than standard injectors.So you think it could be the 02 sensor or TPS?I might try them both, the cheaper one first.. Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1054061 Share on other sites More sharing options...
Guest XR09 Guests Posted 09/11/10 02:34 AM Share Posted 09/11/10 02:34 AM or crank sensor on its way out. Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1054239 Share on other sites More sharing options...
Toecutter Member 182 Member For: 18y 1m 22d Gender: Male Location: Melbourne Posted 11/11/10 06:56 AM Author Share Posted 11/11/10 06:56 AM Thanks guys.Is there any way which I can determine if it is the 02 sensor, crank sensor or TPS?Or will I just have to replace each and wait until the problem stops.. Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1054957 Share on other sites More sharing options...
Toecutter Member 182 Member For: 18y 1m 22d Gender: Male Location: Melbourne Posted 01/01/11 11:02 PM Author Share Posted 01/01/11 11:02 PM Hmm, the problem did go away for a while, has started up again in the hot weather.Doing it every few times that I start the car, then I restart it and it's fine.. Link to comment https://www.fordxr6turbo.com/forum/topic/71521-violent-shake/#findComment-1068316 Share on other sites More sharing options...
