South Member 323 Member For: 18y 7m 6d Gender: Male Location: Perth Posted 22/09/10 02:54 AM Share Posted 22/09/10 02:54 AM Teamviewer is good, but if you use it too often (without buying it) you will have a timeout period of 5mins.Logmein is much better, although full screen is only about 80% of your screen you work from (Black edges) Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042202 Share on other sites More sharing options...
Turbo6FG Silver Donating Members 497 Member For: 15y 1m 29d Gender: Male Posted 22/09/10 05:11 AM Share Posted 22/09/10 05:11 AM I have LogMeIn & have always been happy with what it does. Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042235 Share on other sites More sharing options...
supercharged88 Member 153 Member For: 16y 9m 5d Gender: Male Location: Far Nth QLD. Posted 22/09/10 08:18 AM Author Share Posted 22/09/10 08:18 AM Wow,thanks for all of the replies,I really appreciate it.I will not be using this feature very often.Sole purpose is to log into the second laptop to download data logs from the race boat for analysis when I cant make it to the race meetings.This way I can make tune changes to suit race conditions and check for any issues if required.I was recommended TIGHT VNC today by an IT friend of mine.With the above information , my sole purpose for this set up explained, what are your suggestions now.Thanks. Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042280 Share on other sites More sharing options...
supercharged88 Member 153 Member For: 16y 9m 5d Gender: Male Location: Far Nth QLD. Posted 22/09/10 08:29 AM Author Share Posted 22/09/10 08:29 AM I forgot to mention, I will be using Telstra Broadband if it makes any difference. Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042284 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 9m 13d Gender: Male Location: Aspendale, Vic. Posted 22/09/10 08:54 AM Share Posted 22/09/10 08:54 AM I just wrote a really long write up on ultra vnc and team viewer and had all associated download links etc but stupid forum done a 404 error. If I recall it is cause you put url's in the post. Forum can at least make it say 'modify your post' not make you LOSE EVERYTHING AND not tell you why its a fail post.Unfortunatlly I cbf retyping 100 lines.Tight VNC is gay, use Ultra VNC. To get ultravnc working on your PCs most likely you will need to configure NAT forward rules on your routers to tell VNC traffic to go to your PC. If you have no idea, then forget about it. Teamviewer is great. Bypasses all firewalls. So use that. Unfortunatlly to connect to PC to PC, you will need teamviewer running. It only runs when you doublke click on it to run. Not on all the time unlike ultra vnc. Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042292 Share on other sites More sharing options...
bjc Donating Members 2,823 Member For: 21y 7m 27d Gender: Male Location: Townsville Posted 22/09/10 09:33 AM Share Posted 22/09/10 09:33 AM (edited) +1 for teamviewer. I use it for most of my work when needed as does my brother*Beep*,that's why I Ctrl-A/Ctrl-C if I'm writing a novel, otherwise type it in notepad then add it sometimes! Sucks doesn't it Edited 22/09/10 09:40 AM by bjc Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042305 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 9m 13d Gender: Male Location: Aspendale, Vic. Posted 22/09/10 10:54 AM Share Posted 22/09/10 10:54 AM OR, have a working forum? lol Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042328 Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 17y 2m 14d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 22/09/10 05:15 PM Share Posted 22/09/10 05:15 PM (edited) Sir,Teamviewer... When setting up records the ID, and create your own PW.Logmein - another option...RealVNC, VNC, tinyvnc, blah blah...PCAnyware... Shomypc...Gotomypc...Or even consider looking at MSN/MS Remote Desktop - there is a remote access function within this also.By default we use nd recommend team viewer - very easy to install, run and setup!Or where only a quick or simple job is needed, sometimes we will use the MSN remote support, however does require a request if not setup...Few of the boys systems in here have teamviewer installed from the builders... Now I wonder who would have done that? If you have any issues, we have the setup files loaded on our webserver - happy to give you access to DL directly... But you should be fine - just go to teamviewer and hit "download now it free..." install as non commercial and u should be fine.. Edited 22/09/10 05:20 PM by smicky Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042387 Share on other sites More sharing options...
supercharged88 Member 153 Member For: 16y 9m 5d Gender: Male Location: Far Nth QLD. Posted 22/09/10 06:13 PM Author Share Posted 22/09/10 06:13 PM OK then, I'll give Teamviewer a go.Thanks everyone. Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1042389 Share on other sites More sharing options...
supercharged88 Member 153 Member For: 16y 9m 5d Gender: Male Location: Far Nth QLD. Posted 25/09/10 09:18 PM Author Share Posted 25/09/10 09:18 PM Hi there,I downloaded Teamviewer 5 onto both Laptops and set it up.Teamviewer 5 works great and does everything that I need to do.So a BIG THANKS to all of you that have posted replies to my questions.One last question,Does the free downloaded version,non lisenced not for buisness use work indefinately or does it have an expirey time.Thanks again. Link to comment https://www.fordxr6turbo.com/forum/topic/70666-itcomputer-software-gurus/page/2/#findComment-1043036 Share on other sites More sharing options...
