09/09/10 09:01 AM09/09/10 09:01 AM #1 okay so I'm having the turbo bits but onto my N/A motor, and the tuner said instead of using the factory boost solenoid that requires the xr6t computer/pcm I can use an after market boost controllerI'm not after anything overly fancy with in cabin controlls just something that can be in the engine bay and set to a certain level (wont be changing boost anyway since the tune will be for a set level)was looking at this im wondering if it will work fine with my car?Turbotech manual turbo boost controller- THE ORIGINAL! - eBay Turbo Parts, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 29-Sep-10 08:13:05 AEST)also where to do the 2 lines go? one in the actuator and where's the other line go to?thanks
09/09/10 10:18 PM09/09/10 10:18 PM #2 Hey mate that's not a boost controller that's a bleed valve. They are pretty dodgy things to use I ran one on my drift pig. Buy a proper one
10/09/10 08:03 AM10/09/10 08:03 AM #3 Author just want something simple and not electronic I can use instead of the factory boost solenoidand I dont want anything in the cabin because cops will defect me for it.is this better? Manual TURBO Boost Controller (WRX/Skyline/Supra) - eBay Turbo Parts, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 29-Sep-10 11:11:38 AEST) Edited 10/09/10 08:10 AM10/09/10 08:10 AM by matt47569
10/09/10 08:29 AM10/09/10 08:29 AM #4 They're basically the same thing. I've got the blue one in the skyline, it runs fine as long as you install it properly; I know alot of people who are using the same item without problems.
10/09/10 08:34 AM10/09/10 08:34 AM #5 Honestly, DO NOT use a manual boost controller. Repeat DO NOT lol. I can't be ar$ed explaining all the reasons why....its Friday and beer o'clock in the West
10/09/10 10:44 AM10/09/10 10:44 AM #6 Author would be getting installed professionally anywaylol well if someone would care to explain why not to use one at some point and find me an alternative one otherwise ill prob be getting the second one I listed Edited 10/09/10 10:45 AM10/09/10 10:45 AM by matt47569
10/09/10 01:51 PM10/09/10 01:51 PM #7 Dude you dont need it professionally installed lol, All you do is cut the vacline to the wastegate and install and adjust.Both the ones you listed are sh*t. Reasons.sh*t setup, either use a ball and spring or some other gay way of doing things.Can cause spikesDont hold boost perfect.You can also get creep with em.They are just cheap and sh*t dude. Buy a proper boost controller or you will be sory lol.And they are also detectable anyway.
10/09/10 03:11 PM10/09/10 03:11 PM #8 Author ok fair enough what is a good controller to use then?and all the turbo gear is being installed all together at once by the tuner as im building up parts he will need for the conversion
10/09/10 03:27 PM10/09/10 03:27 PM #9 Author something like this? KGCM2 Dual Stage electronic Boost Controller TYPE-R - eBay Turbo Parts, Performance Parts, Car Parts, Accessories, Cars, Bikes, Boats. (end time 12-Sep-10 17:50:19 AEST)
11/09/10 01:03 AM11/09/10 01:03 AM #10 ok fair enough what is a good controller to use then?the factory one
