Chris and Liza Member 42 Member For: 16y 6m 9d Gender: Male Location: Sydney, New South Wales, Australia Posted 27/08/10 02:41 AM Share Posted 27/08/10 02:41 AM G'day everyoneSince I have owned my T it experiences a knocking sound after startup.Series of events:Startup, drive to almost exactly 10km/h (every time), then it goes knocka-knocka-knocka-knocka-knocka and then no more noise until next startup.Braking performance is normal. I was told that it was the abs unit - because the discs and pads were worn out - but after I fitted new discs and pads the noise came back. I got one start and take off without any noise - woohoo!Any ideas guys?Cheers,Chris Link to comment https://www.fordxr6turbo.com/forum/topic/70217-knocking-noise-abs-unit/ Share on other sites More sharing options...
ebxmple Member 1,322 Member For: 17y 3m 8d Posted 27/08/10 03:41 AM Share Posted 27/08/10 03:41 AM that's just the abs system doing a selftest mate,that's why it does it after each cycle of the key. Nothing to worry about at all. Link to comment https://www.fordxr6turbo.com/forum/topic/70217-knocking-noise-abs-unit/#findComment-1035467 Share on other sites More sharing options...
boost69 Donating Members 737 Member For: 19y 11m 20d Posted 27/08/10 04:43 AM Share Posted 27/08/10 04:43 AM Mine does the same...you start it...then put it in drive and about 5 seconds later you hear that knocking noise for about 3 seconds and then nothing everything is normal...mine does this without fail every time...I have always wondered wether this is normal... Link to comment https://www.fordxr6turbo.com/forum/topic/70217-knocking-noise-abs-unit/#findComment-1035481 Share on other sites More sharing options...
Chris and Liza Member 42 Member For: 16y 6m 9d Gender: Male Location: Sydney, New South Wales, Australia Posted 29/08/10 07:10 AM Author Share Posted 29/08/10 07:10 AM hmm fair enough - I just thought it was a bit unusual that a near new car would make such a noise... Link to comment https://www.fordxr6turbo.com/forum/topic/70217-knocking-noise-abs-unit/#findComment-1035892 Share on other sites More sharing options...
Chris and Liza Member 42 Member For: 16y 6m 9d Gender: Male Location: Sydney, New South Wales, Australia Posted 30/08/10 07:57 AM Author Share Posted 30/08/10 07:57 AM here's a possibility - when I was dismantling my front end (for some nice new nolathane bushes to go in) - I noticed that the brake line coming through the bodywork on the passengers side had chopped through its grommet. I'll fix this and see if it fixes the problem once I get the front end back together. Link to comment https://www.fordxr6turbo.com/forum/topic/70217-knocking-noise-abs-unit/#findComment-1036108 Share on other sites More sharing options...
yz250 Member 3 Member For: 15y 10m 21d Posted 03/09/10 02:19 PM Share Posted 03/09/10 02:19 PM Hey Mate, the noise you describe is definitely the ABS carrying out a self test. My old Ba, the current Bf2 and the old mans Fg all go through the same sequence.Cheers Link to comment https://www.fordxr6turbo.com/forum/topic/70217-knocking-noise-abs-unit/#findComment-1037298 Share on other sites More sharing options...
smicky Go Pies!!! Donating Members 2,852 Member For: 17y 2m 22d Gender: Male Location: Vic Somewhere - Sometimes NSW Posted 03/09/10 02:47 PM Share Posted 03/09/10 02:47 PM (edited) ABS self test..Next service just get them to check the sensors are ok... I had one a bit flakey on the startup test thingy... but once the car had moved and hit the brakes it was fine... Dealers wasnt sure why the 'test' wasnt 100% but the ABS sensor and rest of the system was fine!They just replaced it anyays.. Edited 03/09/10 02:48 PM by smicky Link to comment https://www.fordxr6turbo.com/forum/topic/70217-knocking-noise-abs-unit/#findComment-1037302 Share on other sites More sharing options...
SuckSqueezeBangBlow ʎǝʞuoɯ ɹoıuǝs Donating Members 1,808 Member For: 16y 4m 23d Gender: Male Posted 03/09/10 09:39 PM Share Posted 03/09/10 09:39 PM the manual which comes with the car explains this noise as the ABS selftest. Link to comment https://www.fordxr6turbo.com/forum/topic/70217-knocking-noise-abs-unit/#findComment-1037325 Share on other sites More sharing options...
