Jizza Member 15 Member For: 14y 1m 11d Posted 03/07/10 11:27 PM Share Posted 03/07/10 11:27 PM Anyone know the standard hub to guard measurement for FG XR6 out of interest? Link to comment Share on other sites More sharing options...
bunna Donating Members 813 Member For: 17y 8m 3d Posted 04/07/10 12:51 AM Share Posted 04/07/10 12:51 AM (edited) For an XR6/T/F6 only:Sedan (nominal figures at kerb weight)Front: 366-369mmRear: 371-376mmXR6 Ute, excluding c-cab and e-gas (again, nominal at kerb weight)Front: 394-397mmRear: 395-400mm Edited 04/07/10 12:51 AM by bunna Link to comment Share on other sites More sharing options...
Worm A much better forum Silver Donating Members 3,808 Member For: 15y 9m 6d Gender: Male Location: Victoria Posted 04/07/10 12:55 AM Share Posted 04/07/10 12:55 AM Ute? Or 4wd??? Link to comment Share on other sites More sharing options...
Jizza Member 15 Member For: 14y 1m 11d Posted 04/07/10 11:48 AM Author Share Posted 04/07/10 11:48 AM (edited) For an XR6/T/F6 only:Sedan (nominal figures at kerb weight)Front: 366-369mmRear: 371-376mmXR6 Ute, excluding c-cab and e-gas (again, nominal at kerb weight)Front: 394-397mmRear: 395-400mmThanx Bunna, very informative:Have just swapped the G6 Limited's springs and shocks front and rear for XR6 units, difference as follows.Front was 385mm - now 373mmRear was 390mm - now 375mmWill be interesting to see how / if it settles further.......handling is obviously much improved. Since new (now 15,000km) The G6 stock was crap as expected in corners but over bumps and surface changes it was horendous, worse than the old BF XR6 with 80,000km on it. Surprisingly that is now fixed also.....Wonder if Pedders can examine the stock units I took out and tell me if they were stuffed so I can take them to the dealer with some lube........ 5 times back there in 6 months and they couldnt find an issue, till the front sway bar had rattled its way loose.Interesting they were also the last to have the wheels off, front right wheel nuts today were little more than hand tight Edited 04/07/10 11:54 AM by Jizza Link to comment Share on other sites More sharing options...
bunna Donating Members 813 Member For: 17y 8m 3d Posted 04/07/10 01:01 PM Share Posted 04/07/10 01:01 PM hmmm - those numbers are a little high for G6 suspension...front 374-377mmrear 383-388mmKeep in mind I have tables for alignment angles for every model from heights of 340-410mm at the front and 300-400mm at the rear, so its not like being a little bit off nominal is a bad thing. Link to comment Share on other sites More sharing options...
Jizza Member 15 Member For: 14y 1m 11d Posted 05/07/10 04:32 AM Author Share Posted 05/07/10 04:32 AM Yeah can expect some variance, though cant accept a brand new $38000 car to handle like a VS commodore (in terms of comfort not sportiness) Link to comment Share on other sites More sharing options...
