dan24 Member 20 Member For: 16y 1m 18d Gender: Male Location: Melbourne Posted 10/06/10 11:53 AM Author Share Posted 10/06/10 11:53 AM (edited) No worries, if I have abit of time tomorrow I'll put the stock solenoid back in and see what that does. I'll let you guys know!Thanks for the info. Edited 11/06/10 12:04 AM by RHR No need to quote above post. USE FAST REPLY Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1014936 Share on other sites More sharing options...
dan24 Member 20 Member For: 16y 1m 18d Gender: Male Location: Melbourne Posted 11/06/10 03:40 AM Author Share Posted 11/06/10 03:40 AM (edited) hey guys,well I took out the new solenoid and put the old one back in, but still not working right! had a reading at idle at around 2PSI, so just gonna take it to my mates tomorrow and put on the mechanical boost gauge and see what that reads.still cant find any kind of leaks or loose hoses anywhere, so maybe the unit itself is faulty? who knows!I've posted a pic of where the vac line is connected with the T piece, but as I said have tried directly off the BOV hose too with the same result.so yeh got me stumped? ill have to get onto Turbosmart I think!well I took out the new solenoid and put the old one back in, but still not working right! had a reading at idle at around 2PSI, so just gonna take it to my mates tomorrow and put on the mechanical boost gauge and see what that reads.still cant find any kind of leaks or loose hoses anywhere, so maybe the unit itself is faulty? who knows!I've posted a pic of where the vac line is connected with the T piece, but as I said have tried directly off the BOV hose too with the same result.so yeh got me stumped? ill have to get onto Turbosmart I think!Dan Edited 11/06/10 04:58 AM by RHR Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1015037 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 11m 24d Gender: Male Location: OZ Posted 11/06/10 03:48 AM Share Posted 11/06/10 03:48 AM Sounds like a faulty unit, wouldn't bother with a mech gauge just go back to turbosmart. What a pain :-( Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1015046 Share on other sites More sharing options...
dan24 Member 20 Member For: 16y 1m 18d Gender: Male Location: Melbourne Posted 16/06/10 10:06 AM Author Share Posted 16/06/10 10:06 AM Well I got onto turbosmart and they helped me reset it, all good now!But the only problem I have is that I haven't wired up the rpm signal wire, now I have search and I think I need a sine wave converter or something? But most thread I have seen have been someone trying to install a monster tacho and get flamed.Anyone able to help out with the rpm issue? And if I do need a sine converter, where do you get them from? Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1016430 Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 10m 14d Gender: Male Location: NSW Posted 16/06/10 10:52 AM Share Posted 16/06/10 10:52 AM You need a tacho drive from Ford Motorsport, pretty sure Herrods sell them or if you want them at a cheaper price try these guys that's where I got mine.My link Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1016444 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 9d Gender: Male Location: Perth Posted 16/06/10 03:57 PM Share Posted 16/06/10 03:57 PM why do you want to feed the e-boost an rpm input? The unit will work just fine without the rpm input, if you really want to feed it rpm you will need the herrod/ford motor sport converter. FWIW summit racing have the ford motorsport tach driver for less than herrods Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1016554 Share on other sites More sharing options...
TURBO4LT Member 1,533 Member For: 21y 10m 14d Gender: Male Location: NSW Posted 17/06/10 07:31 AM Share Posted 17/06/10 07:31 AM You can use the rpm signal for a few reasons:1/ To activate a buzzer or light at a set rpm. (Shift alert)2/ To add or remove boost from the top end of the rev range between two set rpm points that you can set to any rpm. This helps in the top end where usually boost drops off.3/ To use the Set point mapping, where you can select boost levels at all 500rpm intervals through out the rev range.4/ To swithch a device on or off at certian rpm points (such as water injection, nitrous and so on)that's what comes to mind quickly.Frank Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1016684 Share on other sites More sharing options...
Ralph Wiggum Moar Powar Babeh Lifetime Members 19,332 Member For: 19y 9m 9d Gender: Male Location: Perth Posted 17/06/10 10:12 AM Share Posted 17/06/10 10:12 AM im well aware of the E-boost capabilities when feed an rpm signal ( I ran an e-boost 2 for over 4 years on my old car, and have it and the ford motorsport tach driver sitting in my shed waiting to go on my current car)My question to the OP is why does he want to run the rpm input and what he hopes to achieve by doing so on a mostly stockcar? Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1016727 Share on other sites More sharing options...
dan24 Member 20 Member For: 16y 1m 18d Gender: Male Location: Melbourne Posted 17/06/10 10:22 AM Author Share Posted 17/06/10 10:22 AM yeah pretty much just want it on there to prevent boost drop off!But yeh is pretty much stock atm, mods goin on pretty soon though, and a tune. As soon as they arrive really, any day now!Dan. Link to comment https://www.fordxr6turbo.com/forum/topic/68694-eboost-street-help/page/2/#findComment-1016735 Share on other sites More sharing options...
