gazman1968 Member 38 Member For: 15y 5m 19d Gender: Male Location: Melbourne East Suburbs Posted 28/05/10 05:14 AM Share Posted 28/05/10 05:14 AM I was wondering which are the best injectors to use in a performance upgrade with power levels up to 350 kw. I was looking at Dekas 60 lbs are there better ones out there ? Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/ Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 10m 20d Gender: Male Location: Aspendale, Vic. Posted 28/05/10 08:18 AM Share Posted 28/05/10 08:18 AM deka 60's are the way to go. Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011391 Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 15y 2m 23d Gender: Male Location: W.A Posted 28/05/10 08:43 AM Share Posted 28/05/10 08:43 AM Deka's are the best and easier for your tuner to tune with over other choices. Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011398 Share on other sites More sharing options...
IH8TOADS Silver Donating Members 3,618 Member For: 19y 10m 30d Gender: Male Location: OZ Posted 28/05/10 09:36 AM Share Posted 28/05/10 09:36 AM (edited) I totally disagree. Any DECENT tuner should be able to pick up an injector, smell it, and get it working pretty darn quickly! Whether it be a deka, nizpro, 968, EV-14 etc no one injector is easier to tune than another....unless the tuner doesn't understand what they are doing. The best injector to use is the one that your chosen tuner recommends. Deside on your tuner, ask their recommendation and then buy it from them or if you think you can get a better price elsewhere then shop around. This will give you the best results. Edited 28/05/10 10:24 AM by RHR No need to quote above post. USE FAST REPLY 1 Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011433 Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 15y 2m 23d Gender: Male Location: W.A Posted 28/05/10 10:15 AM Share Posted 28/05/10 10:15 AM ive been told they are easier to work with by several tuners Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011439 Share on other sites More sharing options...
Paulie2256 Donating Members 7,441 Member For: 16y 6m 16d Gender: Male Location: SE Melbourne Posted 28/05/10 10:46 AM Share Posted 28/05/10 10:46 AM If you only going up to 350 and not much more then 968 would be the way to go imo. they are the closest to stock and have a superior spray pattern (as far as I know). But as IH8TOADS said, ask your tuner. Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011446 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 11d Gender: Male Location: @ my laptop Posted 28/05/10 11:08 AM Share Posted 28/05/10 11:08 AM depending of air fuel ratio required, we have seen 968's maxed out to 100% duty and make 350 rwkw on a manual, would not do this on an auto and not a good idea to run injectors maxed for too long as they will be damaged. Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011454 Share on other sites More sharing options...
RIP_HSV HOON Member 1,636 Member For: 15y 2m 23d Gender: Male Location: W.A Posted 29/05/10 03:21 AM Share Posted 29/05/10 03:21 AM Deka's only way to go!! Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011571 Share on other sites More sharing options...
ratter Member 6,793 Member For: 19y 11d Gender: Male Location: @ my laptop Posted 29/05/10 03:51 AM Share Posted 29/05/10 03:51 AM No, normally they are the cheapest Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011575 Share on other sites More sharing options...
Bo0st3D XR6 Member 57 Member For: 15y 4m 4d Gender: Male Posted 29/05/10 04:00 AM Share Posted 29/05/10 04:00 AM what do people think of bosch EV14s 52lb for assuming for powers no more than 350-400rwkw? im considering them as I assume they are direct fit for the fgs no mods required? for 350rwkw is it better to go for say 52lb or 60lb? Link to comment https://www.fordxr6turbo.com/forum/topic/68444-which-are-the-best-injectors/#findComment-1011576 Share on other sites More sharing options...
