boostjuice Member 3 Member For: 16y 4m 22d Posted 15/05/10 12:45 PM Posted 15/05/10 12:45 PM Can anyone tell me how to replace the oxygen sensor on an BA XR6 turbo?Is it something I can do myself or does it need to go to a mechanic?
Gee Member 131 Member For: 17y 5m 10d Gender: Male Location: Melbourne Posted 15/05/10 11:31 PM Posted 15/05/10 11:31 PM Take off the heat shields covering the turbo Then locate the oxygen sensor, with is locate behind the turbo and has a green plug attached to it. Remove O2 sensor and replace with new one. Replace covers,While the cover are off you should re-torque the exhaust mainfold bolt to 27nm. Job done. Note. If you can remove the o2 sensor with the exhaust is hot, it will un-screw easier.
f-wolf Member 897 Member For: 19y 5m Gender: Male Location: ACT Posted 17/05/10 12:25 AM Posted 17/05/10 12:25 AM If you need a new one ....OXYGEN SENSOR / O2 SENSOR - 4 WIRE FORD SENSORAt: OXYGEN SENSOR / O2 SENSOR - 4 WIRE FORD SENSOR - eBay Other, Engines, Components, Car Parts, Accessories, Cars, Bikes, Boats. (end time 30-May-10 15:31:12 AEST)
