brownhornet Donating Members 124 Member For: 16y 9m 24d Gender: Male Location: Perth Posted 14/02/10 12:28 AM Author Share Posted 14/02/10 12:28 AM I was quoted $60 genuine. That was each if I remember correctly.What are the implications of it being loose? Is the engine sucking dirty air? Link to comment https://www.fordxr6turbo.com/forum/topic/66000-what-is-this-clamp/page/2/#findComment-981560 Share on other sites More sharing options...
Stazza_Brendan Donating Members 686 Member For: 15y 7m 2d Gender: Male Location: Mackay QLD Posted 14/02/10 03:43 PM Share Posted 14/02/10 03:43 PM its probably still got a decent seal on it if the rubber isnt flogged out. Link to comment https://www.fordxr6turbo.com/forum/topic/66000-what-is-this-clamp/page/2/#findComment-981863 Share on other sites More sharing options...
blackxr6turbo Member 61 Member For: 16y 3m 18d Posted 15/02/10 07:18 AM Share Posted 15/02/10 07:18 AM for the skinny ones that fit in the plastic groove - I have looked around at heaps of places but havn't found one to replace the factory one?in the end I got another one from fords, any tips on finding them? Link to comment https://www.fordxr6turbo.com/forum/topic/66000-what-is-this-clamp/page/2/#findComment-982009 Share on other sites More sharing options...
White Knight Donating Members 73 Member For: 15y 6m 23d Gender: Male Location: Sydney Posted 17/02/10 10:05 AM Share Posted 17/02/10 10:05 AM If there is no seal, it's essentially sucking in unfiltered atmospheric (engine bay) air or losing boost, depending on which pipe's coupling is not sealed. Just tighten her up.Not worth putting too much thought into this one IMO Hornet. Your turbo won't blow up from sucking in a little bit of atmosphere or anything.@ blackxr6turbo - before I made Fraud replace mine (as they refused to at first), I bought an 8 inch length from SuperCrudAuto for around $14. Measured the half-way point at a few points around the circumference and carefully cut it in half with a sharp blade. Then replaced both ends on my intake pipe. It fit much more snuggly then the worn factory ones and probably provided a better seal. Oh and it looked trick for the short time I had it on there. Link to comment https://www.fordxr6turbo.com/forum/topic/66000-what-is-this-clamp/page/2/#findComment-982940 Share on other sites More sharing options...
