  • Member For: 16y 8m 23d
Posted
Anyone else out there suffering the problem of the hose which connects via. a flimsy plastic tube into a rubber mount on top of the throttle body keep popping out? Ok, had some minor tweaks to the engine but can't seem to keep the platic section connected to to the top of the throttle body. I've had an interim fix of a bolt through the plastic section and cable tied to the throttle body section but I'm not sure how long this will give me. It's certainly not a permanent solution.
Thanks
  • Member For: 16y 11m 29d
Posted
Had it to the dealer for a possible warranty claim?
  • Legacy Donating Member
  • Member For: 20y 3m 30d
Posted
Yeah the stock rubber joiner isnt the best... make sure its clean inside and doesnt have oil vapours on the surfaces and it "should" be ok on stock boost.
Failing that you can use a new piece of silicon hose, 3.25inch dia, about 60mm long, and some strong clamps.
Atleast the throttle body on the FG has a bigger lip, than BA BF,to join to... one of hundreds of little improvments ford made to the FG
