jimking19 Member 44 Member For: 17y 8m 30d Gender: Not Telling Posted 01/03/10 11:08 AM Author Posted 01/03/10 11:08 AM The filter is located in the banjo fitting for the oil pressure sender/turbo feed line on the LH side of the block.The sound you are hearing on shutoff is the residual pressure of the aircon bleeding through the aircon restrictor/expansion bleed. It is located in a hexagonal crimp in the condenser out line right near the ECU. Try turning the engine off with no aircon selected.Nah, I think he's probably right when he says he can hear the turbo spinning after shutting off the engine. I used to be able to hear it too, used to think it was the water pump. Now that I have a new turbo on it though, it is much quieter. You can still hear it if you're listening for it or you open the hood though. That's to be expected.
Trough Lolly Member 4,349 Member For: 22y 19d Gender: Male Location: Mildura Posted 05/03/10 03:35 PM Posted 05/03/10 03:35 PM .................... This problem happened only a week after I fixed the piping.............................so you were spanking it like a thailand hooker for a week thinking it would be just fine???
