January 23, 201016 yr #1 Mrs and I went for a drive last wednesday from Canberra to Cooma ( NSW ) in the T to see some friends.On the way back to Canberra I took some Temp Readings using my LapTop and an ELM 327 Blue Tooth sender unit plugged in to the OBD port of the car.When driving at 100 Kmh with Aircon on the radings are:Water Temp 90C +- Running a 82C Thermostat.Oil Temp 80C -85C. With Engine Oil Cooler fitted. This reading was taken from Gauge fitted to Car !Air Temp inside Intake Manifold 40C going up to 50C when accelerating.Outsite temp at the time would have been about 35C +-The Temp I was really interested in was the Air Temp in the Intake Manifold. Is 40C high or is it normal. Edited January 23, 201016 yr by f-wolf
January 24, 201016 yr #2 "Air Temp inside Intake Manifold 40C going up to 50C when accelerating"that's the one I would be focussing on. what cooler do you have?
January 24, 201016 yr #4 on the process west site there testing with stock cooler on dyno said temps started at 49c and ended at 67c so I think that's pretty normal
January 24, 201016 yr #6 no probs im actually surprised that u didnt get hotter temps with the aircon on and being a 35c day ford must have a pretty decent cooling system...
January 24, 201016 yr #7 Nice info, Where did you get the sender? And how much was it if you don't mind my asking?Had a quick look on the net and from what I can see they are bout $70, that sound right?Also the device reads fault codes to doesnt it?Seems like a handy little device to have in my toolbox.
January 24, 201016 yr #8 Author Nice info, Where did you get the sender? And how much was it if you don't mind my asking?Had a quick look on the net and from what I can see they are bout $70, that sound right?Also the device reads fault codes to doesnt it?Seems like a handy little device to have in my toolbox. eBay Seller: ed c yu: Electronics items on eBay Australia************************************************************************I also got one of these !This one reads All codes including ABS and will also show LIVE Data. Water and Air and O2 output.MaxiDiag US703 GM Ford Chrysler OBD2 ENGINE SCANNER_CAN Edited January 24, 201016 yr by f-wolf
