woofer908 Member 25 Member For: 16y 5m 10d Posted 02/02/10 01:29 AM Share Posted 02/02/10 01:29 AM Well replacing the fuel pump did stuff all. I took it to another mechanic and fixed it in about two seconds. Turns out the hose running to the boost solenoid was loose and so was another one of the hoses. My sugestion is to check all of these first and make sure that they are tight. This was causing an overboost and shutting the cylinders down Link to comment https://www.fordxr6turbo.com/forum/topic/65394-ba-xr6t-engine-performance-issue/page/3/#findComment-977218 Share on other sites More sharing options...
Kellar Member 51 Member For: 15y 6m 2d Posted 02/02/10 03:10 AM Author Share Posted 02/02/10 03:10 AM Thanks for the reply, we had worked out that our W/Gate actuator was faulty, which was having the same effect as your loose hose. Link to comment https://www.fordxr6turbo.com/forum/topic/65394-ba-xr6t-engine-performance-issue/page/3/#findComment-977244 Share on other sites More sharing options...
Ynot Member 6 Member For: 16y 25d Gender: Male Location: 2300 Posted 09/08/10 02:06 PM Share Posted 09/08/10 02:06 PM I had the same issue. 07 BF stock. Car would idle but would not rev or be able to be driven. Turn it off for 2 minutes start the car and it would drive fine for 3km. Then ground hog day. Limped it back to Ford and they found 2 exhaust manifold bolts MISSING in the section where the turbo meets the extractors. Link to comment https://www.fordxr6turbo.com/forum/topic/65394-ba-xr6t-engine-performance-issue/page/3/#findComment-1031332 Share on other sites More sharing options...
