Ba Xr6T Auto 4 Speed
Featured Replies
#1
Hi people I have just brought a ba 2003 xr6t with 47000 kms on it and was wondering what sort of kw (power) can the standard 4 speed autos handle will they handle 300kw.
And also what small things can you do to improve kw.
I have heard exhaust upgrade can get you 10kw.
Thanks.
Here is a pic.
Edited by Dagabond
#2
welcome to forum mate.
280rwkw is a safe bet with the 4sp auto...anything over then your playing with fire.
full exhaust + dump upgrade, big intercooler+piping, capa flash and 60lb injectors is all you need. if you do those you will need a worked auto as you will be about 320-340rwkw. Most likley need turbo to be ported, larger flapper mod and bigger actuator.
If you want to get 280rwkw, injectors, cooler and zorst + tune is all you need. Heaps of threads. Use the search function and good luck.
Great buy for 2003ba with only 47000km's!
#3
at 280 rwkw I would also fit a tranny cooler ( approx $140)
#4
I've been running 270rwkw for just over a year now, and it's only started slipping recently. Going in for a rebuild at the end of this month :runaway:
#5
  • Author
They have 240kw but that at flywheel right not at wheel what do they have at the wheel standard.
O and thanks for the replys.
#6
BA's anywhere between 170 - 195 rwkw
Recently Browsing 0
