on dubs Member 132 Member For: 16y 9m 28d Gender: Male Location: Gawler, SA Posted 05/11/09 03:29 AM Share Posted 05/11/09 03:29 AM Driving along a main road today when some jerk cut me off, I floored it (in drive) it kicked down and launched like a rocket like never before then all of a suddena big puff of sandy brown coloured smoke came out the back and it started running rough.I pulled over in a side street and check everything out under the bonnet... no obvious signs of any problems.Started her back up, no problem with idle or anything so I took off.Now when I put my foot down and the boost winds all the way up it blows a little bit of this sandy brown smoke comes out. It is coated on the inside of the exhaust tip also.What has happened?Yesterday I cleaned the boost solinoid with some RP7, I let it idle for 5 mins and took it for a hard drive. No problems at all it worked great.I've got a pod filter on in place of the airbox, bov removed and the car is flashed tuned to 10psi. The car was already tuned when I bought it but I suspect that it is a generic tune from capa.One other thing is that under hard throttle it reaches the end of 3rd gear and seems to hit a flat spot and stops pulling. Not sure if these things are connected.Any advice would be appreciated. Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/ Share on other sites More sharing options...
dashturbo Donating Members 280 Member For: 16y 10m 17d Gender: Male Location: Watsonia Posted 05/11/09 04:22 AM Share Posted 05/11/09 04:22 AM Ive never heard of brown smoke... just black, blue and white..how do you mean sandy?All smoke is either oil, fuel, coolant, or some part of the engine/turbo/exhaust, so maybe your catalytic converter?sounds weird to me dude. Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-950688 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 11m 8d Gender: Male Location: Aspendale, Vic. Posted 05/11/09 05:04 AM Share Posted 05/11/09 05:04 AM could of been a bad batch of fuel Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-950706 Share on other sites More sharing options...
Trough Lolly Member 4,349 Member For: 20y 9m 16d Gender: Male Location: Mildura Posted 05/11/09 05:21 AM Share Posted 05/11/09 05:21 AM is the car under 1/4 tank of fuel??if its a sedan you could be getting bad fuel surge. Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-950715 Share on other sites More sharing options...
ZAP No boost, no bottle, just my foot on the throttle! Lifetime Members 7,935 Member For: 21y 4m 11d Gender: Male Location: Sydney Posted 05/11/09 05:22 AM Share Posted 05/11/09 05:22 AM I would be inclinded to believe it is overboosting and when the limp mode kicks in it is unburnt fuel you are seeing.From the rear view mirror ruch smoke looks brown, when from behind the car it is black.lubing up the BC has most likely brough the car back to its full potential and in conjunction with the pod has now caused the overboost problem.Get it custom tuned and it should solve your problem. Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-950716 Share on other sites More sharing options...
on dubs Member 132 Member For: 16y 9m 28d Gender: Male Location: Gawler, SA Posted 05/11/09 06:02 AM Author Share Posted 05/11/09 06:02 AM by sandy I'm just trying to describe the colour of it.there is brown residue sitting in the exhaust tip, slimey to touch.custom tune is definitely on the cards. Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-950726 Share on other sites More sharing options...
seduced Need more power. Now taking donations. Member 753 Member For: 16y 3m 29d Gender: Male Posted 05/11/09 10:56 PM Share Posted 05/11/09 10:56 PM Chances are you are overboosting bad, and leaning out like crazy. I have had the same flat spot in third once, I was running a c&v generic 10psi tune on a freezing cold night. Full throttle saw it register 16psi at the top of third and the ECU shut it down, jumped out of the bonnet, broke my right ankle and punched me in the face.I now keep it on 8psi until I can get a custom tune sorted. Take yours to a tuning shop and get them to have a look, it doesnt sound healthy... Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-951004 Share on other sites More sharing options...
dule Donating Members 1,180 Member For: 18y 2m 9d Gender: Male Location: Sydney Posted 05/11/09 11:40 PM Share Posted 05/11/09 11:40 PM I don't like the fact that it keeps doing it and that slimy brown residue in the exhaust is not a good sign. Hope it's not oil.If it is it's probably your turbo or maybe even engine. But my money is on the hardware and not the tune, tune is probably what caused it. Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-951009 Share on other sites More sharing options...
xr6t_ute Donating Members 2,281 Member For: 18y Gender: Male Location: south east suburbs Posted 06/11/09 12:02 AM Share Posted 06/11/09 12:02 AM your best bet is to run it up on the dyno and see from the back and check what the tune is doing Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-951013 Share on other sites More sharing options...
icer Banned 2,335 Member For: 15y 11m 8d Gender: Male Location: Aspendale, Vic. Posted 06/11/09 02:10 AM Share Posted 06/11/09 02:10 AM well, if its the turbo....you better be quick. im selling my modified turbo. can just simply bolt it on to replace yours. check my forsale thread. Link to comment https://www.fordxr6turbo.com/forum/topic/63322-blowing-brown-smoke/#findComment-951046 Share on other sites More sharing options...
