  • SUPERLAP 2011
  • Member For: 19y 5m 22d
Posted
hi guys. havin a few lil problems with my new setup
basicly im running the following...
process west plenum kit (not the race)
process west surge tank
62lb injectors
4" xforce exhaust with the 3.5 single catback
etm external gate kit with screamer (slightly modified to move gate so as not to foul on dump)
being tuned with vcm
basicly what we have got is this, it will make 17psi of boost off gate pressure and then drop off to 13-14psi. we have tried using a ball and spring style tap to control boost and stil no success.
we have tried it with the cat removed and same scenario
we have played with the timing to see it that was affecting it and still same scenario
we have not tried it with the ford standard ebc though being external gate it should still hold pressure / control boost
is there possibly something in the vcm program that needs to be disabled when not using the ford boost controller
anyone able to tell me what we have missed?? is it likely to be a dud gate?
any help would be much appriciated
regards adam
  • Banned
  • Member For: 17y 1m 29d
Posted
you obviosuly also have done valve springs too right?
  • SUPERLAP 2011
Posted
Yes. We have done springs too. Sorry forgot to add that.
  • Member For: 19y 5m 3d
Posted
there is your problem. the ball and tap boost controls are crap at the best of times. grab a electronic boost control and see how you go.
and please don't buy a turbosmart EBoost as there are crap............. personal experiences saw me lunch many engines.
try a GReddy Profec or E01 boost controller.
hope that helps
  • Legacy Donating Member
  • Member For: 20y 3m 27d
Posted
What psi spring is it it?
When I had the gt45 on the old BA, I first had a 7psi spring, using profecB to control, with 15psi dialed in it would slowly get to 15psi (at 4500rpm which sucked) but fall back to 13.
Fitted a 20psi spring, bypasses the profec so just on spring rate, and had a flat 20psi from about 3500 up
In my case I belive the 7psi spring was just to soft, the 20 was too high but did fix the slow uneven boost issue... a 15psi spring was going to be my next one to try.
May not be the same deal with yours, but that's what I found anyway.
  • Inactive Members
  • Member For: 18y 1m 30d
Posted
Check your Gate
2 things
your diaphragm may be pinched (if you have changed springs) or the piston on the gate may be not seating properly on the ring
let us know how you go
  • 2 weeks later...
  • SUPERLAP 2011
Posted
your a tripper laborio... You bin speakin to pedro? Yeah as you know we had those 2 lil issues aswell as the intake filter and pipework wasnt flowing enough so we went away from the ubcai to a 4'' intake in a box where the battery sat
  • SUPERLAP 2011
Posted
read post above yours mate... was not a faulty gate
