Benji_vs Legacy Donating Member 403 Member For: 18y 4m 22d Gender: Male Location: East Suburbs Melbourne Posted 04/07/09 01:58 AM Posted 04/07/09 01:58 AM I have this noise when the car is cold as well, its not super loud but yes it sounds like a peg in a bike wheel, ive been told that it may be an exhaust leak, or could it possibly be the heat shield rattling????? Either way I dont think its the bearings because ive looked at my turbo many times and spun it free hand and its moves nicely. If your worried about the bearings take the inlet tube off and check for shaft play or rough movement. Hope that helps a little
ebxmple Member 1,322 Member For: 18y 7m 29d Posted 04/07/09 05:41 AM Posted 04/07/09 05:41 AM Exhaust leak? Have you pulled your heatshields off and tightend over manifold and turbo.Can you here it if you load it up in gear when cold,maybe get someone to listen to it if it does.Have you checked your turbo oil feed line and filter for being blocked? Might be starving the turbo a bit when cold.Drivebelt or idler pulley? Again try load it up stationary and see if you can here it.
xcerlence Legacy Donating Member 13 Member For: 17y 9m 28d Gender: Male Location: sydney Posted 05/07/09 09:26 PM Author Posted 05/07/09 09:26 PM thnx for all your help guys. I took everyones examples and found it was one of the bearing on the fan belt that was making the noise. it was turning at full capacity and once I gave it abit of throttle it found it hard. so I changed the bearing and now its fine thnx all for your help
ebxmple Member 1,322 Member For: 18y 7m 29d Posted 06/07/09 08:06 AM Posted 06/07/09 08:06 AM Good stuff mate,saved yourself some coin.
