April 24, 200917 yr #1 Guys,Couple of questions;How do I remove the tray highlighted... It appears to be separate from the rest of the unit, so not that difficult... but how do I get it out? If you could post a quick 1,2,3 step process on getting that out would be fantastic! (pictures would be awesome, I don't want to f*ck my console up :( )I think you have to remove the "sides" of the center dash, so how and where do I do that without doing damage? where are the clips?Also, does anyone know someone in Brisbane that does roof upholstery - IE; change the material from gray to black or some other material
April 24, 200917 yr #2 You need to take the 2 side peices off first then take out the 2 screws holding the tray in.
April 24, 200917 yr #3 to get to the side pieces you need to remove the surround around the gear lever ,it will just pop up gently lift each corner till it comes loose then you will wsee all the screws you need to
April 24, 200917 yr #4 Guys,Couple of questions;How do I remove the tray highlighted... It appears to be separate from the rest of the unit, so not that difficult... but how do I get it out? If you could post a quick 1,2,3 step process on getting that out would be fantastic! (pictures would be awesome, I don't want to f*ck my console up :( )I think you have to remove the "sides" of the center dash, so how and where do I do that without doing damage? where are the clips?Also, does anyone know someone in Brisbane that does roof upholstery - IE; change the material from gray to black or some other materialnice picture maybe a little more Conservative next time, we dont want ppl to get the wrong idea!!!
